Member # 74849
here what I did.
1. bought 3 ammo cans for $30: -1 30 cal -2 50 cal (the fat ammo cans) 2. had 4 1" spacers, and extra bolts (free) 3. bought a Tuffy tie down kit for $20 (yeah I could made them but I don't have the time). So I drilled 4 holes, bolted the 2 50 cal cans together, drilled and bolted the tuffy tie downs to the tub, and then bolted the 50 cal cans to the tie downs. The 30 cal can isn't bolted down because that's for my first aid kit and I wanted it to be carryable. anyway here's some photos. ![]()
Livin' the dream
Member # 77297
Here's my set-up
Nothin' is holding you back but fear and good common sense. Thanks to Axial Racing,Yukon, Crystal Basin Mt. Resort, Norcal Crawlers, MSD,P-ville Kiwanis,El Dorado Rotary,Metalcloak,Magoon Signs,www.4wdmechanix.com, Northstar Eng,Crawl,FOA,AND BFG for supporting WFTW. |
Member # 1792
In my Jeepster the seats are mounted to the cage with 1.5/.125 square tube.I mounted a 50 cal ammo box between the front seats to the crossbars.
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers.Kids 70Jeepster fullwidth on 34/9.50 swampers. |
Member # 72752
not exactly "bolt on", but they are bolted to the tub.
I built two boxes on top of the wheel wells, ![]() ![]() then I built a "truck" that fits behind the rear seat, ![]() the trunk section can be moved forward(when the seat is out, and I need more storage), and a lid/tonneau can be added. ![]() the seat brackets are still in place, and it only takes a few minutes to remove the tonneau section and reinstall the seat.
93YJ, mostly stock,4.0, AX15, 231, D30 &35, 3" lift, TJ flairs, and 33's. Last edited by muddyj; 07-27-2009 at 07:44 AM. |
Member # 78377
thats a pretty cool setup.
you guys who are using wood. what are you treating it with to keep it in good shape. ive used thompson water seal on my trailer but water still seems to warp the wood after just a year |
Member # 72752
I used wood for mine, and just covered it with a couple coats of spray can bed liner. it's been in for about 3 years now, and is holding up pretty well.
93YJ, mostly stock,4.0, AX15, 231, D30 &35, 3" lift, TJ flairs, and 33's. |
