Detroit Locker Question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-05-2009, 05:28 AM   #1 (permalink)
Muffburger
mean green's Avatar
Member # 62908
I have a 98 TJ that I recently swapped 79 Ford 60's under with 5:38gears and 37's. I am putting in a new clutch kit tonight due to some bad chatter and shimmy coming from the drivetrain when I release clutch. As I was inspecting the whole drivetrain for anything else that may be contributing, I noticed I could grab my rear driveshaft and turn it a 1/4 rotation before the anyhting caught. This is with the tires on the ground. There would be a clicking sound then the Dshaft would catch. I removed diff plate to check gear mesh and backlash. They were both excellent. The pinion and the ring gear move 1/4 pinion turn back in fourth before the tires want to turn. The play is inside the Detroit? Normal? This is my first run at a Detroit and this is probably normal but I was going to pull it and inspect it tonight if not. Thanks.
98 TJ
mean green is offline   Reply With Quote
Old 08-05-2009, 06:53 AM   #2 (permalink)
Member # 40587
It's normal. Lots of people ask it here, even detroit has said there are no problems. Detroits are naturally sloppy like that. Mine was a 1/4 turn as well before anything caught. Other then pulling into parking spots and the driveshaft wanting to slam back and forth if I didn't let the clutch out a little bit to put pressure on it, it was never an issue.
The first day I got my axles in (total rebuilt, regeared D44s) I damn near shit a brick because I thought the gear install was fucked up from all the slop in the rear diff because of the detroit.
[QUOTE=Dieselmh]I'll cave his fucking head in with a shovel, just to show him that just because he has opposable thumbs, that doesn't put him on the same badassedness level as humans. Stupid arrogant possums. :shaking:[/QUOTE]
The Black Sheep is offline   Reply With Quote
Old 08-05-2009, 07:15 AM   #3 (permalink)
Muffburger
mean green's Avatar
Member # 62908
10-4
Thanks!
98 TJ
Old 08-05-2009, 08:34 AM   #4 (permalink)
The Devils Trailboss
UCTJ's Avatar
Member # 51571
Agreed! You will hear this from people with an auto tranny often because they put it in park and yet the rig may roll a bit because of the slop in the Detroit it freaks some out thinking theres a problem with the tranny or the locker.
UCTJ is offline   Reply With Quote
Old 08-05-2009, 09:24 AM   #5 (permalink)
Brads_nky_yj's Avatar
Member # 119995
Great info! Im getting ready to stuff my waggy 44's with detroits on both ends and would have probably freaked out a little as well.
93 YJ - SOLD
Brads_nky_yj is offline   Reply With Quote
Old 08-05-2009, 10:03 AM   #6 (permalink)
BootPartyCoordinator
JolietJames's Avatar
Member # 111254
Same here
I have the same slop from the Detroit in my Rockwell and had it in my D60 as well.
JolietJames is offline   Reply With Quote
Old 08-05-2009, 10:19 AM   #7 (permalink)
Muffburger
mean green's Avatar
Member # 62908
Dl
I think my clutch issue is making it feel worse so hopefully after I put the new clutch kit in tonight it wont be bad at all.
98 TJ
