Brakes on 8.8 Diff - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-20-2009, 07:45 PM   #1 (permalink)
JNJTJ's Avatar
Member # 137866
Brakes on 8.8 Diff
I'm a newbie so go easy on me, I have an 06 TJ I just did a Ford 8.8 diff with disc brakes swap. The problem is the rear brakes seem to work but not very well. I've done some research and have found some people talking about taking a master cylinder from a Dodge P/U and putting it in a jeep and other people not doing anything saying it works well enough. Since this TJ is also our daily driver I would like to have better then well enough brakes. As for the E-brakes I found a kit from M.O.R.E. Offroad that I can use. Can anyone help me with my problem?
JNJTJ is offline   Reply With Quote
Old 08-21-2009, 12:04 AM   #2 (permalink)
jrw7072009's Avatar
Member # 135054
On a 06 I would say you should be ok with what you have. I have a few customers with 8.8s with discs in there TJs and there brakes work fine. I would double check and bleed the heck out of the rears make sure there is no air in them at all before changing out your master cylinder.
jrw7072009 is offline   Reply With Quote
Old 08-21-2009, 04:43 AM   #3 (permalink)
Member # 87845
look for the porportioning valve mod.
lots of people have pulled this little grommit out of their stock MC to address this issue.
in my case, rear brakes seem fine, and I havent found this mod necessary.
y2knole is offline   Reply With Quote
Old 08-21-2009, 05:18 AM   #4 (permalink)
Little Jeep's Avatar
Member # 58117
I agree....... on an 06 you shouldn't have any issues. I did the swap on my 1998 and never saw the need to mess with the combination/proportioning valve. Are you sure you have the calipers on the correct sides? Bleeder valve should be at highest point..... if not, you will never be able to get all the air bled out.
Little Jeep is offline   Reply With Quote
Old 08-21-2009, 05:20 AM   #5 (permalink)
Ruiner of the Things
AlxJ64's Avatar
Member # 130031
I have done a few 8.8 swaps as well, including in my old daily driver. I snagged a prop valve out of a V-8 Disc rear grand cherokee and swapped that in. Compared to with the stock valve and the ZJ valve, it stopped twice as good.
'97 TJ -SM465, KluneV/D20, HO72/HP60, ORIs, 40" Comp Treps
http://www.pirate4x4.com/forum/showt...=781656&page=3
'42 Dodge WC53 - Cummins CRD, Allison 1000, HO72s F/R, 38" Michelins
http://www.pirate4x4.com/forum/tow-r...airstream.html
AlxJ64 is offline   Reply With Quote
Old 08-21-2009, 08:03 AM   #6 (permalink)
JNJTJ's Avatar
Member # 137866
Thanks guys, this helps lot, I'll start by bleeding the brakes agaiin and move on from there
Old 08-21-2009, 02:39 PM   #7 (permalink)
Member # 108872
Send a message via AIM to MonsterSeven Send a message via Yahoo to MonsterSeven
didnt all 06 TJs have disc brakes in the rear?
*98 RHD TJ: swapped 4.0L/AX-15/Dana 300, 4.88, AEV 3", LP9"/S88, Grizzly/Detroit, OTK steering, 35" muds... 84:1.
*85 CJ-7: GM350/NV4500/D300, SOA on Wags, LP44/LP9", Aussies, 37" MT/Rs, Staun beadlocks, hi-steer, 110:1... in pieces.
MonsterSeven is offline   Reply With Quote
Old 08-21-2009, 04:49 PM   #8 (permalink)
Member # 115721
Did the "grommet" mod on my master cylinder, works great.
Also, if you haven't already bought the MORE kit, look into stock ZJ brake cables. I use them and they work fine, and are cheaper. I think they were about $35 each from the stealership.
00TJ4L is offline   Reply With Quote
Old 08-21-2009, 08:51 PM   #9 (permalink)
AlxJ64's Avatar
Member # 130031
I've always used stock cables... Just cut a few loops of the guard cable off of the end, and with a small ferrel and a clamp you can clamp around the lever arm and it works great.
Old 08-23-2009, 12:53 PM   #10 (permalink)
JNJTJ's Avatar
Member # 137866
brake cables
Thanks guys, those are both great ideas I'll try that before spending $125 on cables from M.O.R.E. then if I don't like the way it works I always have the option of buying cables
