quick question what shackle to run , soa with fortn wagoneer spring - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-05-2009, 01:50 PM   #1 (permalink)
Member # 143347
i have a 95 yj soa and wagoneer front springs( 2" of wheel base stretch) what type of shackle should i run . i currently have a 1 1/4" lift shackle 6 1/4" from bolt hole to bolt hole in the front, i feel this is too much ( i had them lieing around so i used them) i was thinking of redrilling them an inch and a quarter shorter to give me a 5/8" lift or should i do it even shorter for a 3/8" lift. .
yjkrawler25 is offline   Reply With Quote
Old 11-05-2009, 02:47 PM   #2 (permalink)
Member # 40587
I like the smallest shackle in the front that I can get away with. Less sloppy steering, no pinion or caster issues, get it as close to stock as you can and run it.
The Black Sheep is offline   Reply With Quote
Old 11-05-2009, 04:55 PM   #3 (permalink)
Member # 143347
how do you stop the front leafs from bending near the rear of the spring hanger
Old 11-05-2009, 07:27 PM   #4 (permalink)
brendanbreen's Avatar
Member # 128819
one of two ways... 1) shackle reversal or 2) do go driving silly fast into things
brendanbreen is offline   Reply With Quote
Old 11-06-2009, 09:18 AM   #5 (permalink)
Member # 143347
i think i going to go back to the shackle reversal setup, and use a waggy shackle in the rear spring mount. i already have the long driveshaft in the front from when i used to run srs. thanks for the imput
