Member # 149675
Best Lift kit for 00-04 Jeep Grand Cherokee?
Whats the best lift kit for a Jeep Grand Cherokee Laredo. Years 00-04. I had a rough country lift on my wrangler, but I was not impressed. I am going to lift my Jeep 3 inches, but I want something that is going to keep the on road driving nice and straight and not uncomfortable. Let me know if you can help. Thanks
Member # 122916
Not sure of what your looking to spend but, URF extreme body lift comes to mind. They are the best lift you can buy. You will have to do 4 inch though because you have a Laredo. It comes with a sick t-shirt too.
Member # 116007
You might want to ask this question in the non-hardcore section. I suggest you read the Cherokee mission statement as well
Bones Heal, Chicks dig Scars, Pain is Temporary, Glory is Forever - Evel Knievel |
Member # 133593
I don't know what your budget is, but this one is adjustable
"The American people sleep peaceably in their beds at night because US Soldiers stand ready to do violence on their behalf" 2000 XJ Classic: 4.5" lift, 4.56's, Alum Beadlocks, 35's, and all the other soccer mom add-ons 1948 Willys CJ2a: stock for now 2000 Audi S4 Stage II |
Moderator
Member # 10249
LOL that is the funniest thing Ive seen in a long time...
![]() Moved to non-hardcore..
Dave, 2013 KOH "Got, Some of it" #697 JIMMY'S 4X4 Grand Cherokee Buggy ADS Shocks LQ4-Th400-Atlas4sp D60 14B Come wheel with us WheelingArizona.com Ashman's youtube channel |
Member # 141317
I would look into Old Man Emu, its part of ARB but they make really good suspensions and in different spring rates for bumpers or a winch.
1981 Jeep Wagoneer-360/TF727/NP219/D44/AMC20 1980 Jeep CJ7 Buggy-350/SM465/NP205/D44/FF14B, SOA |
Member # 141297
I had a 2000 wj for about 3 years or so with a 4" suspension lift from Rusty's Offroad. It drove and performed really well, I did however have 1.75" poly spacers on top of the rusty's springs to be able to fit the 33's I was running. The poly spacers added enough lift to really flex the 33's but the rusty's arms that come with the kit are not adj. so my wheelbase was a little shorter then most. If I were to recommend this lift to anyone I would say 31'' tires w/ no cutting or 33's with cutting,spacers, and adj control arms.
If you want to go real nice look at Rockkrawler or Ironrock Offroad longarm kits for the wj. |
#8 (permalink) | |
Member # 143035
get adjustable track arm, 3" springs, front disconnects, A-arm rear upper ball joint spacer block optional. then make rear shocks fit front with home brew eyelet conversion at the top and bar pin eliminators at the bottom. then use menroe shocks from a f250 in rear. I can give the part #. I have 13"travel in front and you should get close to that in the rear with the rear a-arm spacer block. I have 10" with out and I know this is likely the limiting factor. custom make your bump stops. for the rear sway bar extend the links and leave it hooked up all the time. try flexing with it. should not need to disconnect but experiment. I have mine not even on. I intend to put it back on for onroad handling and from researching I have found that it may be ok to just leave on. you may find springs and spacers for sale on forums. OME 2.5" springs and 1"spacers would be a great combo. the most spacer and spring combo you can use is 2" for the spacers. when you install it you will see why...LOL. interested in more just ask. if you do an extreme trim 33" is possible but you will need less backspacing than factory wheels or use wheel spacers with factory wheels. 1" to 1.25" would be good. I am going to 5" springs and eventually clayton long arm kit. I have researched this quite abit. to get 35's under it I need to push out the axles. I wont be investing a dime into the factory axles D30 and D44A. not strong enough. will be looking for HPD44 front or D60 and D60 rear. will truss that and go for it....LOL |
