YJ trackbars - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-10-2010, 10:14 PM   #1 (permalink)
Member # 149984
YJ trackbars
Is it necessary to have them? I am building YJ with just a mild lift of about 3" and am wondering if you need em. I have taken them off now and sure noticed a huge change in highway driving. Seems like you need to be on the wheel alot.
Also, on the subject of puttin waggy springs for the lift. What do I use out of the pack?
Tx in advance for any tips. Am new to offroading.
I do use this for my daily driver at this time so need it road worthy.
Wrangler dude is offline   Reply With Quote
Old 01-10-2010, 10:31 PM   #2 (permalink)
billybadass411's Avatar
Member # 84882
This is far from hard core........GTFO.
Screw track bars with leaf springs.
billybadass411 is offline   Reply With Quote
Old 01-11-2010, 12:48 AM   #3 (permalink)
2 Wheeler
sb643's Avatar
Member # 138077
WTF are you talking about; you notice a "change in highway driving."??
Maybe if your bushings are shot, in which case your shit's all retarded because your bushings are shot.
To paraphrase the previous post- If you have leaf springs, and are concerned with trackbar/panhard rod necessity go take a JC beginning auto course, or do some fucking research about suspension. You may not have noticed the supersecretmembersonly search function of this site, but it's at ~12:38. If you still can't find it, go to google. Either way, don't waste our time with your nonsense, Troll.
Tits can't even save you. GTFO.
As for your BS about waggy springs or whatever the hell you said, I must reiterate- GTFO.
sb643 is offline   Reply With Quote
Old 01-11-2010, 04:29 AM   #4 (permalink)
Member # 49116
No you don't need them. For 8 yrs i did not have them and it was my DD.
As for waggy springs. You want to run the hole waggy front spring pack. Front and rear and it will give you a little wheelbase stretch. Now you better go back to the non hardcore before the wolves get really fired up.
Mach2_nh is offline   Reply With Quote
Old 01-11-2010, 06:00 AM   #5 (permalink)
cavaliers1323@aol.co's Avatar
Member # 69669
Really?
[URL=http://www.standardproduce.com/]Standard Produce Co.[/URL]
Serving Central VA Since 1910
93 YJ N/A 383 on 'pane 405hp/435tq NV4500 6.34:1 231/300 10.88:1 Locked Tons 5.38's 40's 108" WB Gettin' There :grinpimp:
cavaliers1323@aol.co is offline   Reply With Quote
Old 01-11-2010, 06:46 AM   #6 (permalink)
89breaker's Avatar
Member # 64213
Originally Posted by sb643 View Post
blah blah blah
Stop being an asshat DAN.
OP, move this thread to newbie, browse around some more before you post again.
You keep coming in here with this stuff is going to piss people off who are looking for hardcore tech.
This is your freebie.
89breaker is offline   Reply With Quote
Old 01-11-2010, 10:35 AM   #7 (permalink)
Moderator
geberhard's Avatar
Member # 5861
X2, dump the rear trac bar. I would say also dump the front trac bar, the leaf springs will do a good enough job on keeping the axle centered. Plan to keep the front with sway bar disconnects and you should be good and not notice a huge amount of change. I
f you removed them and you are noticing immediate amount of change on the front, inspect your leaf spring bushings for wear.
As far as Waggy springs, I personally would not run them SUA, the packs will not perform as well unless you remove a lot of leafs. If you have them, and if tehy are the 8 leaf pack, you will ned to remove at least three leaves to keep the ride decent, otherwise be ready for a very bumpy ride. Waggies on SOA are a whole other story
geberhard is offline   Reply With Quote
Old 01-12-2010, 10:48 AM   #8 (permalink)
Member # 149984
You are a brutal bunch for sure for forum trolls. Damn. Not very friendly people here I guess. Who the hell needs ya anyways. Just asked some simple questions for christs sake. Take a pill and get your panties out of your ass.
Old 01-12-2010, 10:51 AM   #9 (permalink)
Member # 149984
So I posted in the wrong spot I guess. You GTFO you idiot. I asked a question and to have your dumbass come out from under your rock just to be a smartass, well I guess the rock says it all ASSHOLE
Old 01-12-2010, 10:53 AM   #10 (permalink)
Member # 149984
Tx to the guys that replied correctly
Old 01-12-2010, 10:54 AM   #11 (permalink)
Ibuildembig's Avatar
Member # 26504
Send a message via Yahoo to Ibuildembig
I agree, most of the people are web wheelers anyway.
As Jeep recycler I say ditch the rear but keep the front. That's the way I have done the last 9 spring overs and they drive great. My 2 cents
If you have a mullet and play video games, your not tellin me shit
68 F350 CC project
72 F350 CC for parts
79 F150 with tons on coils
88 F350 truggy
90 F350 beater truck
96 F250 CC DD
Ibuildembig is offline   Reply With Quote
Old 01-12-2010, 11:07 AM   #12 (permalink)
Member # 24681
My old jeep was sprung over and I didn't have any track bars on it front or rear and had absolutely no handling abnormalities. That being said it also had a high steer setup on it. Without the front track bar and a normal steering set up you may have issues with bump steer.
WavRidr is offline   Reply With Quote
Old 01-12-2010, 11:53 AM   #13 (permalink)
89breaker's Avatar
Member # 64213
Edit: Thread was moved.
Old 01-12-2010, 12:43 PM   #14 (permalink)
Member # 40587
Apparently this got moved.....
Short answer no you don't need track bars. Fix your junk correctly and replace any worn out parts if your rig is all over the place.
Also, you probably want to check out this website, you will probably find that these guys are more your crowd. www.jeepsunlimited.com Theres nothing but cranky assholes and web wheelers on this site. The guys that really know what they are talking about are over there.
The Black Sheep is offline   Reply With Quote
Old 03-11-2010, 01:28 AM   #15 (permalink)
Member # 149984
Thanks Black Sheep. But because of the web wheelers and cranky assholes, I think I'll stay. Just to keep em cranky
Old 03-11-2010, 07:53 AM   #16 (permalink)
Member # 87682
Well said,I dont run them(spring over) if you dont like the way in handles without run it.(front)
wranglerwilson is offline   Reply With Quote
