tom woods drive shafts - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-13-2010, 10:57 AM   #1 (permalink)
Member # 71504
i have a 1310 cv shaft on the rear of my jeep. the shaft is about 6 mo old and it ate the centering ball out of the d/s and the ujoints are good. the jeep is a yj with a 4.0,t18,d300 1.5 re spring over springs. has any body else had a problem like this.
high clearence is offline   Reply With Quote
Old 01-13-2010, 01:41 PM   #2 (permalink)
Member # 88959
Same thing just happened with my TW at 8 mos. Call them up, they may be able to help you.
IOUnlimited is offline   Reply With Quote
Old 01-13-2010, 05:01 PM   #3 (permalink)
Trail Rated
mphudak's Avatar
Member # 64714
X2...Call up TW and talk with them. Pretty stand up company with the experience I've had.
mphudak is offline   Reply With Quote
Old 01-13-2010, 05:24 PM   #4 (permalink)
Antman's Avatar
Member # 13620
I have had and seen this happen. The problem I have seen is
either the operator has failed to grease the CV joint or it came from TW's
without grease in the CV joint. As a rule when you by a new drive shaft, be
sure to grease it before you install it.
97 TJ 4.0L with modifications 106" WB
4:1 Locked front and rear with 37" MTR's
R.I.P. Lowtech and Skii4X4
Antman is offline   Reply With Quote
Old 01-13-2010, 07:35 PM   #5 (permalink)
troydigby's Avatar
Member # 77494
yea this happened to me also after a few months. i got it fixed locally worked for a while, then went out on my, then it went out on me again after 5k miles..... sucks! but i believe it is an opperator error. i have a belly up and a 4" lift with no limiting straps. i guess the driveshaft bottoms out all the time when offroading and at high speedy or something.. but now im putting a little tcase drop on, getting limiting straps, and making sure i grease it everything i get my oil changed.
TJ, 14" coilovers, 3 link & 4 link,44 & 8.8, 40" MTRs on Walker Evans, Atlas 3.8, 103" WB
troydigby is offline   Reply With Quote
Old 01-14-2010, 10:20 AM   #6 (permalink)
Member # 114864
Send a message via AIM to EvulutioN
Angle is key for CV-shafts - they are more sensitive than standard shafts...
The ball is what pretty much absorbs the vibration of a bad angle...check your angles with an actual angle finder...if you have a 4-link out back there shouldn't be any axle wrap. if you have leafs out back you may have more axle wrap than you think, too. I know I did...
-::82 CJ7 with Stuff and Things::-
EvulutioN is offline   Reply With Quote
Old 01-16-2010, 09:31 PM   #7 (permalink)
onetoncv's Avatar
Member # 2160
Make sure to grease the needle fitting that is the hardest to find -that's the one that hit's the ball- Jess
http://highangledriveline.com
Bringing Innovation to the market !
http://highangledriveline.com/HAD1.gif
530-877-2875
onetoncv is offline   Reply With Quote
Old 08-05-2010, 02:03 PM   #8 (permalink)
Member # 159343
I have so much trouble greasing those needle fittings...is it just better to drop the shaft from the tcase to get to it?
Jeep02Apex is offline   Reply With Quote
Old 08-05-2010, 02:15 PM   #9 (permalink)
Member # 127808
I just sent mine back to TW to get rebuilt. The shaft side joint in the CV was going after 10,000 miles (4 months). Center ball seemed okay. The plan is to rebuild the CV, rebalance, and return ship it to me in a day or so. So far I'm pretty happy with the service.
'05 TJ, 3.5" lift.
BubbaWilkins is offline   Reply With Quote
Old 08-05-2010, 03:19 PM   #10 (permalink)
The Devils Trailboss
UCTJ's Avatar
Member # 51571
Yes. Thats exactly what I do every few months.
93 W250 CTD 5spd
97 TJ 60/14 Atlas 40" Maxxis 106" WB
Shawn
www.polyperformance.com
UCTJ is offline   Reply With Quote
Old 08-06-2010, 04:39 AM   #11 (permalink)
PumpkinCrusher's Avatar
Member # 81449
Just got Tom Woods shafts this week. I've bought from him before because of his reputation and good quality. I did receive with this shipment a grease nozzle to fit on the end of my grease gun to gain better access to the CV joint. He sent that free along with a hat.
PumpkinCrusher is offline   Reply With Quote
Old 08-06-2010, 08:44 AM   #12 (permalink)
Member # 159343
Brian Peppers, by grease nozzle do you mean needle fitting? And WTF, I bought two shafts from him and never got a hat
Old 08-06-2010, 08:51 AM   #13 (permalink)
Member # 162819
Or a free fitting.
I just ordered one from Woody's Auto Supply today though since next time I change my oil will be time for me to grease the centerball.
jgkjeep is offline   Reply With Quote
Old 08-06-2010, 09:53 AM   #14 (permalink)
Member # 68024
Send a message via MSN to A-Dam Jeep
I can't seem to keep any grease in the center ball. I'll grease it go to town or for a short wheeling trip and its dry by the time I get home. Other than that I'm very happy with the shaft.
A-Dam Jeep is offline   Reply With Quote
Old 08-06-2010, 10:00 AM   #15 (permalink)
rkik's Avatar
Member # 34591
What is the best way to get grease to the center ball if it is a stock CV joint without the needle fitting? Disassemble the outer u-joint so i can pull the ball apart? Or should I just get a ball rebuild kit that comes with needle fittings and swap out the stock one?
rkik is offline   Reply With Quote
Old 08-07-2010, 06:34 PM   #16 (permalink)
Antman's Avatar
Member # 13620
Wow! TW is aware of this problem evidently. You got to grease that sucker to make it live.
