CJ10A SD33 fuel filter - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-26-2010, 05:53 PM   #1 (permalink)
Member # 138064
I was wondering if anyone had a part number for the fuel water seperator filter mounted under the battery tray.
wcurleyq is offline   Reply With Quote
Old 01-27-2010, 04:43 AM   #2 (permalink)
jeepinwilson's Avatar
Member # 34804
I will get it for you later unless one of the other guys comes up with it first. I have a few new elements and a filter base if you need any spares. I removed them when I did an engine swap. Oh, and you might want to move this, it is not hardcore..... and you will get eaten alive with insults.
1947 Willys
jeepinwilson is offline   Reply With Quote
Old 01-27-2010, 05:50 AM   #3 (permalink)
OCX Off Road Audio
TAWL_BOY's Avatar
Member # 72810
Mine has a WIX 33386 on it.
Custom Speaker Cans for Your Buggy, Side by Side, or Boat
LIKE US
Use PBB15 for $15 OFF Order of $130+
TAWL_BOY is offline   Reply With Quote
Old 01-27-2010, 01:31 PM   #4 (permalink)
Member # 138064
Is that the one under the battery tray mounted to the frame with a plastic drain that screws into the bottom, or is it the one that screws on the filter base mounted to the engine?
Old 01-27-2010, 01:44 PM   #5 (permalink)
OCX Off Road Audio
TAWL_BOY's Avatar
Member # 72810
I have that same filter on both.
That's how I got it from the military.
LIKE US
Old 02-17-2010, 06:43 AM   #6 (permalink)
Member # 140071
I dont know ,if you still need it .
Here is some info about SD33 filters.I add air and oil filters too.
SD33
oil filter:
ac-delco pf1052
baldwin pt153
hastings/amsoil LF365
fram (don't use) ch3505
air filter:
baldwin pa2174
ac delco a790c
amsoil ts16/lt16/lst18
80 scout sd33t air ca133/oil ch3505
79 scoult sd33 air ca133/oil ch3505
ca133 10" OD - 7.75" ID 2-11/32 height
ca3497 11-7/32" - 9-3/32" - 2-7/16"
fuel filter (larger size):
Part Number: 3393 - $11.55
UPC Number: 765809152793
Principal Application: Hino, Isuzu, Mitsubishi, Nissan,
Toyota Diesel Trucks (Secondary) (10 Micron)
Style: Spin-On Fuel Filter
Service: Fuel
Height: 4.069
Outer Diameter Top: 3.234
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
Burst Pressure-PSI: 290
Max Flow Rate: 8-10 GPM
Nominal Micron Rating: 10
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.487 1.987 0.140
Description Baldwin Filter BF954 Fuel Filter, Spin-On,
Length 3 7/16 In,
Outside Dia 3 1/16 In,
Thread Pitch 3/4-16
NAPA 3386: Part Number: 3386 - $9.86
UPC Number: 765809152731
Principal Application: Various Hitachi, Isuzu, Komatsu & Kubota Equipment,
TCM Forklift, Toyota Forklifts (10 Micron)
Service: Fuel
Height: 3.197
Thread Size: 3/4-16
Burst Pressure-PSI: 255
Gasket Diameters
Attached 2.475 2.173 0.233
armymec is offline   Reply With Quote
