97 tj steering box - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-09-2010, 05:24 PM   #1 (permalink)
OUTLAW MOTORSPORTS
4doorchevy's Avatar
Member # 69112
97 tj steering box
my steering box started leaking fluid faster than I can put it in. Which one is the best upgrade? what fits back in stock location?
97 tj 6.0 nv4500 241c on tons in the works
4doorchevy is offline   Reply With Quote
Old 02-10-2010, 07:05 AM   #2 (permalink)
Member # 141244
I am partial to PSC's myself.
"Trouble finds me in easy places."
SweetPee is offline   Reply With Quote
Old 02-10-2010, 07:20 AM   #3 (permalink)
Member # 40587
Another stock steering box from the junkyard. You don't need a PSC box (they are great products) if its just used alone, you really aren't getting much benefits. If your steering is totally tricked out with hydro assist, all the measurements are right, you aren't running that stock garbage that came stock in terms of linkages then by all means, PSC is the shizz. If its just a daily driver, or light trail rig.
The Black Sheep is offline   Reply With Quote
Old 02-10-2010, 12:06 PM   #4 (permalink)
OUTLAW MOTORSPORTS
4doorchevy's Avatar
Member # 69112
Does it have to be off a 97 tj? what else will fit?
Old 02-10-2010, 12:20 PM   #5 (permalink)
Member # 99723
Should have posted this about a week ago. I threw one away that i took off. Nobody wanted it.
Moore87 is offline   Reply With Quote
Old 02-10-2010, 12:25 PM   #6 (permalink)
Member # 40587
Any TJ box should fit. I'm not sure if a YJ box will or not.
Old 02-10-2010, 02:16 PM   #7 (permalink)
OUTLAW MOTORSPORTS
4doorchevy's Avatar
Member # 69112
well if it would've broke a week ago i would've. thanks anyway
Old 02-10-2010, 04:03 PM   #8 (permalink)
RGRHASH's Avatar
Member # 108388
Mine was the same way for over 5 years( )...I beat on it for about another 1.5 yrs after that till it wouldnt hold fluid AT ALL, not a drop...It would pour on your feet while you were topping it off( and the resevior was all brown inside from dirt getting into the box through the seal).It wouldnt pass inspection in TX...I went with an Entire PSC steering setup(hydro Assist) since Im still on the street occasionally..I cant remember what a stock box cost( like $400 or so?) I figured Id put that money towards the PSC stuff, and I think it was worth it..But like I said I didnt have the thing working for nearly 6.5 yrs...
RGRHASH is offline   Reply With Quote
Old 02-11-2010, 01:47 AM   #9 (permalink)
Member # 102053
Durango box, 98-99. I put one on my 05. 03 and up you have to modify one bolt hole and use a pressure hose from an early TJ, but you should be able to bolt in, drill out a nylon pin in steering shaft and go.
Drilling out the pin may not apply on the early TJs.
pachary is offline   Reply With Quote
Old 02-14-2010, 08:15 AM   #10 (permalink)
Member # 13820
The older cherokees and especially j truck boxes will bolt in. I have one from a j20 and dont think I had to modify anything. Of course it was on there for 6 months and started leaking again. not bad but it seaps.
DO NOT buy a reman from the big box stores, I had 2 of them and at dang near 300.00 each they are a ripoff.
You know West Texas Offroad used to rebuild these pumps for about half of a reman unit. That will likely be my next step. I agree PSC rocks but if you are lile me, I only run 34's and dont really have any money so junkyard replacements are alright by me.
97 TJ with a few toys.
Rio_Grande is offline   Reply With Quote
Old 02-14-2010, 02:46 PM   #11 (permalink)
OUTLAW MOTORSPORTS
4doorchevy's Avatar
Member # 69112
I found one in a junkyard for fifty bucks. Now if i can get off work long enough to go get it
Old 02-14-2010, 05:19 PM   #12 (permalink)
Member # 153886
98 Durango w/ a V8 is a direct bolt in with no modifications on the early TJ's. It's a little bit bigger box but bolts right up with no other mods.
SoCalKenny is offline   Reply With Quote
Old 02-14-2010, 05:40 PM   #13 (permalink)
OUTLAW MOTORSPORTS
4doorchevy's Avatar
Member # 69112
thanks for all the info
Old 02-15-2010, 07:37 AM   #14 (permalink)
Member # 41802
FWIW, I run a PSC box, stock pump through a cooler and turn my locked 33's with ease. I had to replace my box a while back and figured eff it, I'll go PSC and see how the stock pump works. year and a half later stock pump still works fine. Couldn't be happier...
Calling an illegal alien an 'undocumented immigrant' is like calling a drug dealer an 'unlicensed pharmacist' -
Toolbox is offline   Reply With Quote
