xj upper control arms - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-13-2010, 10:09 PM   #1 (permalink)
Member # 62289
ok does any one have a after market upper control arm for a xj . if you do can u tell me how long is it from end to end . i have a 5.5 lift on my xj and my upper control arms r shock so they are to short . i have after market lower arms and my axle is push out on the bottom . so i need to make some news one for the top . but i don't now how long they should be .
freedomhunter is offline   Reply With Quote
Old 02-13-2010, 10:25 PM   #2 (permalink)
Member # 103442
Send a message via AIM to GreatWhiteXJ
Stretch out a piece of bacon and use bubble gum to stick it in place.
XJ on 42's
GreatWhiteXJ is offline   Reply With Quote
Old 02-14-2010, 12:20 AM   #3 (permalink)
Member # 81189
Just take off your upper arms, and position the axle
exactly where you want it. Put a jack under the pinion
and rotate the axle around, making sure you don't put the Castor
into the negative. Don't tip the pinion up too far!
Once you have the axle where you want it exactly...
Just measure the mounting bolt holes for the upper arms
and build them to that length.
That's why they make tape measures.
Amazing what you can do with things?
'88 Jeep MJ 1-ton buggy
barillms is offline   Reply With Quote
Old 02-15-2010, 03:19 AM   #4 (permalink)
Member # 144317
snagged from jeepforum , this gives you a rough idea...
The lowers to set your wheel base, the uppers to tune your caster.
Lift...........Lower Control .............Upper Control
...............Arm Length ................Arm Length
................Decimal--Fraction.....Decimal--Fraction
Stock........15.75.......15 ¾........15.00.......15
2”.............15.92.......16............14.88.... ...15
3”.............16.09.......16............14.92.... ...15
4”.............16.33.......16 3/8......15.03.......15
4.5”..........16.47.......16 ½........15.11.......15
5”.............16.62.......16 5/8......15.21.......15 ¼
6”.............16.97.......17............15.44 ... ...15 ½
7”.............17.36.......17 3/8......15.74.......15 ¾
8”.............17.81.......17 ¾........16.09.......16
9”.............18.30.......18 ¼........16.50.......16 ½
10”...........18.82.......18 ¾........16.96.......17
johnnybebad is offline   Reply With Quote
