JK axles on a Tj - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-16-2010, 02:38 PM   #1 (permalink)
Member # 154214
JK axles on a Tj
i found a guy in New York who is selling a dana44 and dana30 w/ 4.10 gears off a 2007 jk, and i was wanting to know if they will fit on a 2004 tj
dyepntballr is offline   Reply With Quote
Old 02-16-2010, 02:40 PM   #2 (permalink)
Member # 82586
Negative..
Rubicon1313 is offline   Reply With Quote
Old 02-16-2010, 02:47 PM   #3 (permalink)
Member # 154214
why wont they? would it take a lot of modding?
Old 02-16-2010, 02:57 PM   #4 (permalink)
Member # 116600
All the brackets are different. You might be able to use a couple but I think almost all of them have to be moved. Unless you designed a suspension around them. And the bolt pattern is different, and they are wider. And when all the hardcore guys get here, you are going to hear something about bacon and or it's Tuesday.
JA66 is offline   Reply With Quote
Old 02-16-2010, 03:03 PM   #5 (permalink)
cavaliers1323@aol.co's Avatar
Member # 69669
I dont care if its TUE, but i do love bacon.
If you cant even read the rules to know your posting in the wrong section, I doubt you could even swap "bolt on axles" ......
And why the fawk do you want to put a D30 in even if it was free.
THIS IS A QUESTION FOR NON-HARDCORE.
[URL=http://www.standardproduce.com/]Standard Produce Co.[/URL]
Serving Central VA Since 1910
93 YJ N/A 383 on 'pane 405hp/435tq NV4500 6.34:1 231/300 10.88:1 Locked Tons 5.38's 40's 108" WB Gettin' There :grinpimp:
cavaliers1323@aol.co is offline   Reply With Quote
Old 02-16-2010, 03:14 PM   #6 (permalink)
Member # 154214
my bad about posting in the wrong area. im jus interested in the d44. my origional plan was just to put 4.56s in the tj and be done with it but i know in the future ill be going to a 44 and this one came up and already had the 4.10 gears aleady in it plus for the price the 30&44 were cheeper then me just putting new gears in my tj
Old 02-16-2010, 04:05 PM   #7 (permalink)
imped4now's Avatar
Member # 124275
Go ask the question in Non-Hardcore and then go back to pbnation.
imped4now is offline   Reply With Quote
Old 02-17-2010, 01:00 PM   #8 (permalink)
Moderator
geberhard's Avatar
Member # 5861
It can be done, but figure about another $250 in brackets per axle. I had a JK rera axle on a TJ, and kept front TJ with adapters to match the wheel pattern in the rear and width.
Both axles are stronger than TJ axles (30 and 44), so not a bad way to go if you are getting a good deal. the front JK axle housing is debatable as far as strength.
if you do not care about being a bit wider not an issue
geberhard is offline   Reply With Quote
Old 02-17-2010, 01:04 PM   #9 (permalink)
yjjeepster's Avatar
Member # 144191
Bolt patterns did change so you will need adapters or new rims as well.
yjjeepster is offline   Reply With Quote
Old 02-17-2010, 02:49 PM   #10 (permalink)
Drive slideways
Member # 81214
no debate about it. The front JK30 is a POS in stock form
Never Monday is offline   Reply With Quote
Old 02-17-2010, 02:56 PM   #11 (permalink)
Moderator
geberhard's Avatar
Member # 5861
yep, I have only seen 44front cracs so far, maybe the 309 gang is not beating them up yet too hard
Old 02-17-2010, 03:18 PM   #12 (permalink)
Drive slideways
Member # 81214
it's the same 2.5x.250 tube, just longer....the TJ's had a bad problem with them bending....the JK will be worse.
Old 02-17-2010, 04:03 PM   #13 (permalink)
Moderator
geberhard's Avatar
Member # 5861
On the Jk's I saw two with actual cracs, not bends. I believe there are some pics posted around here on the front 44's, looks almost like cast..
Old 02-17-2010, 04:05 PM   #14 (permalink)
Drive slideways
Member # 81214
I've never touched a JK44, don't know.
I guess it's posible they got some quality Chinese steel for a batch of tubes.
Old 07-06-2012, 12:30 PM   #15 (permalink)
Member # 179826
Resurrection as I am starting this swap in a few weeks to give my TJ dana 44 front and rear
d'sjk is offline   Reply With Quote
