CJ5 steering too sensitive - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-05-2010, 06:45 AM   #1 (permalink)
Member # 51175
My CJ5 resto project is finally on the road but I hate driving it. The steering is super sensitive and its down right scary at anything above 45 mph. While I can control it, it's not practical or safe. How can I slow the steering on my jeep? It has power steering(Saignaw?), stock width axles, and 33" Goodyear MTRs. Not the best combo in the world but I need to make it work.
Thanks
Chris
GixRider is offline   Reply With Quote
Old 03-05-2010, 07:00 AM   #2 (permalink)
oldjeep's Avatar
Member # 3511
Check your caster angle. I'm betting that you installed lift springs/shackles and messed up the castor which can make it really twitchy.
I'm sure someone will disagree with me, but for power steering I set the caster to 7 degrees on my old CJ and it worked well.
Chuck P
The clowns'? Oh, yeah, the clowns. We fight them too — entire armies, spilling out of Volkswagons. We do our best to fight them off, but they keep sending 'em in!
www.oldjeep.com
oldjeep is offline   Reply With Quote
Old 03-05-2010, 08:40 AM   #3 (permalink)
nofender's Avatar
Member # 25958
Sounds like you may have swapped in a quick ratio sterring box. If so, it would be a simple swap out to a different ratio. I ran a Camaro box on my CJ years ago. Lasted a day. Downright scary.
nofender is online now   Reply With Quote
Old 03-05-2010, 11:28 AM   #4 (permalink)
Member # 51175
Thanks guys.. I didn't put the lift on or buy/install the steering box. I'll check caster tonight then look into the steering box if the caster is correct.
