yj stretch ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-09-2010, 05:43 PM   #1 (permalink)
Member # 134106
yj stretch ?
i am looking to stretch my yj 2" will probably use the 44044 springs. it is an 89 yj soa with a waggy 44 front and a 9" rear. i was wondering if any one had done this stretch with just using tj flares or if i would have to take some more body out. O and i am running 36" tsl's.
kasbiker38 is offline   Reply With Quote
Old 03-10-2010, 01:50 AM   #2 (permalink)
xPOLYMATHx
LucasFury's Avatar
Member # 113176
Send a message via AIM to LucasFury
That's gonna be like 9" of lift..
Dirty deed done dirt cheap!
and custom leather belts and such too.
1979 FSJ Chief almost for sale. Inquire within.
LucasFury is online now   Reply With Quote
Old 03-10-2010, 09:06 AM   #3 (permalink)
vayacondios
beefdawg's Avatar
Member # 87698
the center pin on the 44044 have a 2 inch offset. So go for it, you can gain 2 inches in the front and 2 inches in the rear. On the front I was running a d44 with high steer arms and a M.O.R.E. steering box mount, shackle reversal and it worked fine. Being that I was running 38.5 tsl sx, I had to add hydro assist, another easy modification. You may have to trim you rear wheel openings.
80 cjunk7, with stuff--SOLD
new build... 90 yjunk, longer, wider, more stuff,
fasten your seat belt, it makes it harder for the aliens to suck you out of your rig
NRA LIFE MEMBER
beefdawg is offline   Reply With Quote
Old 03-10-2010, 03:13 PM   #4 (permalink)
Member # 138518
curious about this. I heard that if you simply slide the leafs back before you bolt them on the rear axle it will stretch it. but this makes no sense to me what so ever. the DS wouldn't fit then.. . ?
tha5150 is offline   Reply With Quote
Old 03-11-2010, 06:57 PM   #5 (permalink)
Member # 134106
any pics of jeeps on waggy springs or 44044's
Old 03-12-2010, 12:44 AM   #6 (permalink)
xPOLYMATHx
LucasFury's Avatar
Member # 113176
There are, but not as many as you might expect, especially on 44044's. It's just too tall. Look up the 'SOA second thoughts' thread on here. If you're dead set on SOA, use stock height springs. Your axles won't live up to any tire size that would necessitate anything more.
EDIT: I meant to add that you can drill a new offset center pin in stock height springs and accomplish the same thing as waggys, but with less lift.
Old 03-13-2010, 12:47 PM   #7 (permalink)
Member # 134106
my jeep is already soa, and i have cromo's front and rear but how do the stock waggy springs work out.. also my hangers are Frenched.
