XJ 30 to TJ - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-26-2010, 07:38 AM   #1 (permalink)
Member # 87682
XJ 30 to TJ
I have a club member with a TJ Dana 30 low pinion, he is looking to buy a 30 out of an XJ,it is high pinion with ARB, 4.56 gearing. will it bolt into the TJ?Both have coil springs but are mounts & brackets in the same place?
wranglerwilson is offline   Reply With Quote
Old 03-26-2010, 07:54 AM   #2 (permalink)
Member # 4375
Direct bolt in swap. The only differences besides the pinion location and reverse cut gears are the LCA tabs don't have cam bolt horseshoes which is a good thing, and the swaybar link bolts press in with a knurled shoulder. They look like they can be turned and removed, but you have to back up the head side with a heavy chunk of tubing and smack them out with a hammer to remove them like a wheel stud.
mrblaine is online now   Reply With Quote
Old 03-26-2010, 12:54 PM   #3 (permalink)
Member # 87845
depending on what year the HP30 is have him keep and re-use his TJ shafts if they're stock in both axles. they slip right in and have the larger u-joints.
keep the HP shafts around to use as spares.
y2knole is offline   Reply With Quote
Old 03-26-2010, 01:59 PM   #4 (permalink)
Member # 87682
Thanks all.
