looking to go lower - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-08-2010, 07:09 PM   #1 (permalink)
Member # 116329
looking to go lower
currently i have a rubicon 4 1/2" lift and a 1" body lift w/35's on my 98' tj. i want to go lower and i'm trying to nail down what combonation of parts to go with. so, if i stick with the 35's and go with high line fenders what size springs can i go down to? also what would i do if i decided to go with 37's? and should i remove the body lift or keep it? i have a sye with a double cardan custom length drive shaft is there going to be a problem with it being to long as i come down in height? i know these are alot of questions but i have looked at a lot of posts and am more confused now than before.
mondols1 is offline   Reply With Quote
Old 05-08-2010, 07:19 PM   #2 (permalink)
Banned
trkklr77's Avatar
Member # 29016
pull the body lift first because its free.
if you still arent happy then get shorter springs.
every jeep is going to be setup different so nobody is going to be able to tell you how to do it and exactly what it will take.
Old 05-09-2010, 11:44 AM   #3 (permalink)
Gabe88's Avatar
Member # 52827
I'm running the white rhino hylines up front and clear 35s easy! The rear flares I removed and cut the sheet metal up to the bottom of the wheel well and pulled the inner fender out.
I've got a 2.5 sky jacker and a 1.25 body lift with the motor mount lift also.
But the suspension has been on there for at least 4 years that I know of, so no telling how much it actually gives me now though.
Gabe88 is offline   Reply With Quote
