no fuel/no spark - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-27-2010, 03:54 PM   #1 (permalink)
Member # 130080
no fuel/no spark
i have checked everything i can find, all fuses and relays are good, ignition switch is good fuel pump works well, i have no power running to my fuel pump and no spark. i've been going through everything for 2 days now and cant find my problem.
jeepbonehead is offline   Reply With Quote
Old 05-27-2010, 05:32 PM   #2 (permalink)
PumpkinCrusher's Avatar
Member # 81449
Need more details? Howell kit, OEM ?
PumpkinCrusher is offline   Reply With Quote
Old 05-27-2010, 07:03 PM   #3 (permalink)
Member # 123988
check engine light come on with the key in run position?
Wolfghost is offline   Reply With Quote
Old 05-28-2010, 12:37 AM   #4 (permalink)
Member # 130080
wiring is all oem, fuel pump is an inline pump from summit.
not the last time i tried
Old 05-28-2010, 03:16 AM   #5 (permalink)
Member # 123988
check power and grounds to ecm, if it checks out replace ecm.
Old 05-28-2010, 05:12 AM   #6 (permalink)
Member # 2790
this would be my guess.. I had a similar problem with a Dodge truck,no codes no CEL...
Russ
hy_desert_4wheeler
46 Dodge WC15--67 M715--85 Jeep CJ10A--06 Dodge Ram2500Quad cab Cummins--94 Suburban--06 Ridgeline-
hy_desert_4wheeler is offline   Reply With Quote
Old 05-28-2010, 11:09 AM   #7 (permalink)
Member # 130080
ecm=computer?
Old 05-28-2010, 11:42 AM   #8 (permalink)
Member # 81449
Yes. Should be located behind the glove box.
Old 05-28-2010, 12:03 PM   #9 (permalink)
Member # 130080
i thought it's in the engine bay on the drivers side fire wall
Old 05-28-2010, 12:14 PM   #10 (permalink)
Member # 130080
just checked voltage to ecm, correct me if i'm wrong, positive is pink with yellow stripe and ground is black. with those i got 12 volts. could any sensors make my fuel and spark turn off
Old 05-28-2010, 03:13 PM   #11 (permalink)
Member # 123988
yes cam position sensor and crank position sensor would make the ecm turn off fuel and spark BUT you would still have the check engine light, looks to me like you need an ecm.
Old 05-28-2010, 05:35 PM   #12 (permalink)
Trailbusters4x4 club
FuzzyZ's Avatar
Member # 117547
Yup ECM would be the most likely cause that i can think of for the problems your haveing and not getting a CEL. All your voltage checks can be fine but if one of the boards in the ECM went bad ya got a problem there, not really a good way to check it with out swaping it or taking it in to get checked.
83 toy pickup, 02 TJ, 02 GMC 2500HD
Trailbusters4x4 club Solano County
Dont blame me i voted Republican!
ECV 1004
FuzzyZ is offline   Reply With Quote
Old 05-28-2010, 09:22 PM   #13 (permalink)
Member # 130080
if i swap in a friends is there any chance of frying his? or should i be okay?
Old 05-28-2010, 11:17 PM   #14 (permalink)
ONEtonXJ's Avatar
Member # 145633
what year and model is your rig??
used to have an '01 XJ... long story short....
XJ died... check engine light followed...
no fuel pressure...
replaced fuel pump...
still no fuel pressure...
check engine light revealed bad crank sensor...
so what im tryin to say here is... MYYY crank sensor.... turned off everthing...
"Tater2" - '91 2 door XJ. 4.0, AW4, 231/300 doubler, GM 60/70HD, 6.17s, ARB's & 4Ds
ONEtonXJ is offline   Reply With Quote
Old 05-29-2010, 03:44 AM   #15 (permalink)
Member # 130080
i replaced the crank sensor already
Old 05-29-2010, 08:16 AM   #16 (permalink)
HARD ROCK VEGAS
burtv's Avatar
Member # 83644
do all other electrical components operate correctly?
burtv is offline   Reply With Quote
Old 05-29-2010, 05:04 PM   #17 (permalink)
Member # 130080
fixed it. but after i replaced my ignition switch and my crank sensor the ecu was bad. i put a friends in that has the same year make model engine and trans and it came right to life. who know where the cheapest place is to get a new used or refirbished ecu
