98 TJ Gauges, Radio, and Interior light not working - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-10-2010, 06:49 PM   #1 (permalink)
Member # 115187
Trying to help out a buddy with some odd issues,
98 TJ 4.0 Auto
The Gauges, Radio, and Interior light has stopped working all at once, All fuses check out. Searched and allot of people point to the plugs on the cluster, which we have checked. Not sure how that would affect the radio and the interior light.
Any Suggestions?
-[B]Mike[/B]
_____________________________________________
My Build - [B]
[/B]
[B]
[/B]
burrellsjeep is offline   Reply With Quote Quick reply to this message
Old 06-10-2010, 07:36 PM   #2 (permalink)
Member # 139130
Jeep had an issue with the ground wire on some of these. They had 2 ground wires, 1 under the dash on the driver side and one under the dash on the passenger side. Sorry but don't recall exactly where and which one was for what. Mine had issue with the one on passenger side and about half my dash lights would not work some of the time.
Maybe that will help out.
I will see if I can locate my diagram and remember where the ground wires are exactly. You should be able to search for this and find it on the internet.
merkchop is offline   Reply With Quote Quick reply to this message
Old 06-10-2010, 09:03 PM   #3 (permalink)
Mud4me!!'s Avatar
Member # 64078
My 98 TJ radio is not hooked up to the factory wiring, and the interior lights are unplugged because i keep the doors off. As for the gauges, mine go dead all the time. Just push the top right corner of the surround for the gauges and they come right back on.
Mud4me!! is offline   Reply With Quote Quick reply to this message
Old 06-10-2010, 09:06 PM   #4 (permalink)
Member # 158579
Hey dude this just happened to me a month ago check the wire that runs up to the speakers on your rollbars i pinched mine on accident. And i got in my jeep and started driving and nothing worked(Radio, guages, Dome light) just check that cluster of wires that runs up to the rollbar speakers.
NEWBIE
tncrawler99 is offline   Reply With Quote Quick reply to this message
Old 06-10-2010, 09:42 PM   #5 (permalink)
Member # 139130
That may be where the ground wire was. On mine it is usually the heater/ac section that I goes out and you can tap the dash around the glove box and they come back on. I need to pull it apart and run a new ground wire one day, but for now a gentle tap does the trick.
Old 06-11-2010, 04:25 AM   #6 (permalink)
Member # 115187
Thanks for the info,
He said he hit the roll bar on a tree, But thought it was after the stuff stopped working I am betting this is it.
Thanks again
-[B]Mike[/B]
My Build - [B]
[/B]
[B]
[/B]
Old 06-12-2010, 06:58 AM   #7 (permalink)
Member # 115187
Had him unplug the sound bar. Still nothing. If it were pinched in the sound bar, would he need to reset any thing or say pull the battery lead or so? Any other suggestions.
-[B]Mike[/B]
My Build - [B]
[/B]
[B]
[/B]
Old 06-13-2010, 11:25 PM   #8 (permalink)
Member # 139130
Don't have good schematics handy, but from the ones I have at hand. Double check fuse # 17 in the Power Distribution Center and #10 in the fuse block.
These are the only ones that I see that are common to your problems.
If they are good, then my guess will be a bad ground wire.
Let me know what you find and if they are both good, then I will try to find my good schematics and see what I can find out.
Also there would be no need to re-set anything if it had been a pinched wire. If the wire was pinched to the point that it was shorting out it would have blown a fuse anyway.
Old 06-13-2010, 11:45 PM   #9 (permalink)
waynehartwig's Avatar
Member # 35700
I think starting in 98 all of those items you describe go through the instrument cluster and are controlled by the PCM. Me thinks your cluster took a dump.
I've got a good working one out of an 04 Rubicon if you need one... Make me an offer
Hartwig Motorsports 4516, Team Yukon Gear and Axle
10% PIRATE COUPON CODE (not valid for harnesses and PCM tuning): pirate4x4
Special thanks to: My Family and Friends, Yukon Gear and Axle, DynoMAX Exhaust, AllTech Motorsports, Radflo Shocks, PAC Racing Springs, JM Rigging Supply, Reid Racing, Rugged Radios, Trail-Gear, Life-Time LED Lights, RuffStuff Specialties, Randy's Racing Transmissions, A1 Performance Converters, Maxxis Tires, Jesse Haines Fab, CBR Performance, PRP Seats, Exhaust Solutions, DiffsOnly.com, and 150Tunes.com
waynehartwig is offline   Reply With Quote Quick reply to this message
Old 06-14-2010, 06:03 AM   #10 (permalink)
Member # 115187
Thanks, For the info
I will let ya know on the cluster
-[B]Mike[/B]
My Build - [B]
[/B]
[B]
[/B]
