Member # 162900
Anyone using Waggy springs?
Wondering if anyone is using front wagoneer springs and would like to post some pics,specs,opinions
I want to run front waggy springs all around on a yj seems like a nice cheap alternative to a lift kit, plus im not looking for tons of lift and i like how it lifts the jeep as well as extends the wheel base
Member # 6340
Location: Telluride CO, within site of of Black Bear Pass
I run waggys in the front and CJ stockers in the rear. SOA They work fine.
Marc In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good." Super conversion calculator website Love and kisses, Zaphod.. Last edited by ItsaCJ6; 07-04-2010 at 03:26 PM. |
Member # 1635
Full size Wagoneer springs are about 57" long. They have a 26 - 31 split.
YJ or CJ are 44" long, and the spring bolt centered 22 - 22. You'll gain some length with them on the wheel base. Longer springs are always good for better flex and ride. However, if you've anything limiting flex now, it will still limit flex with the Waggy springs. Check out the thread "How to get the most Leaf spring flex" My view is longer leafs are better, and the junk yard provides plenty to try different custom configurations. Leaf springs are a wear item in this sport. Some spring info: /forum/jeep-hardcore-tech/775943-info-leaf-spring.html My drive shafts are made in my garage.
Proud Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html |
#8 (permalink) | |
Member # 1635
Front Waggy info Front Leaf Springs 1976 - 1992 Jeep Wagoneer / Full Size Cherokee / J10 / J20 Pick up leaf springs # Leaves Width...... Measures (A/B)..... Pack Thickness (D)....Spring Capacity 5 ........... 2-1/2........... 22-1/2 x 24-1/2........... 1-5/16............ 960 7........... 2-1/2........... 22-1/2 x 24-1/2........... 1-13/16........... 1335 7........... 2-1/2........... 22-1/2 x 24-1/2........... 1-15/16........... 1455
#9 (permalink) | ||
Member # 162900
#12 (permalink) |
Member # 108388
Here is some more info, dont know if you hade seen it already or not...As always, you'll have to verify the accuracy..Here you go, might be useful:
http://www.universityofjeep.ca/stretching_yj.html Last edited by RGRHASH; 07-08-2010 at 07:44 PM. |
#14 (permalink) |
Member # 55871
OX--- you are running stock Waggie spring reversed SUA and running 39"s? I thought they only netted around 2" lift? Am I missing something? Please more input.
1980 CJ7-4.56, 35x12.50 LTB's, locked F/R, cage. It's easier to get forgiveness than permission. |
#15 (permalink) |
Member # 156136
x2 on more info. Also, searched a bit and didn't find any definate answer. But if you buy lift springs for a waggy, does it still hold true that you add an additional 2" to the spring? Thanks
#16 (permalink) |
New Beginnings
Member # 99513
Platform is a 1993 Jeep YJ:
Running Stockish front waggy springs in the front, bastard built spring pak to get my ride height. Its SOA, about 5" lift overall, with 12" travel shocks. I guess I could go 14" if I redid the lower shock mount at the axle. But I had limited room to work with since I installed a HP60 from a 89 F350(shorter driver side tube) This also shifted the front axle forward 3.1 inches gain in WB. Used stock OEM steering box with stock waggy Pitman.(no drop) I do have a short thread on here somewhere in non-hardcore. Just got to go dig it up out of the dirt somewhere.
My jeep is a hotrod! /forum/jeep-hardcore-tech/658004-going-against-odds.html ![]() NEW BEGINNINGS: /forum/general-4x4-discussion/971511-jealle-o-cigano.html |
#17 (permalink) |
Member # 41013
Stock front Waggy flipped with an added spring. I took the main spring of the rear pack to build the military wrap. I mounted the spring hangers on the bottom of the frame for a little added height, I also have a 1 inch body lift.
#20 (permalink) |
Member # 26995
Looking hard at the Wags for the inevitable mods to the YJ sitting in the driveway. Target tire size is going to be 35's; thinking Wags SUA & TJ flares...1" body lift if that is not enough.
I want to avoid hacking sheetmetal on this one. Would 35's go?
2002 Ford Focus Wagon...baby seat, pull-down sun shades, and drink holders front & rear |
#21 (permalink) |
Member # 41013
I think 35 should fit clean with no body lift. Keep in mind that the spring hangers on the YJ are in the frame and the ones on my TJ are on the bottom, you will lose a little height. Look at this, he is YJ SUA with waggys.
http://www.pirate4x4.com/forum/showt...&highlight=sua |
