Replacing a floor - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-20-2010, 09:58 AM   #1 (permalink)
Member # 45290
Send a message via AIM to BoneCrusher
Replacing a floor
82 Scrambler
engine turns over electrical works
floor is rotted out.
I mean I need to cut out the whole floor and star over.
Anyone have a thread where someone has done this?
what do I use for Floor suport?
How do I recreate the body mounts?
Thanks in advance
and yes i searched.
It's never how far or fast you CAN go. It's always how far or fast you WILL go.
BoneCrusher is offline   Reply With Quote
Old 07-20-2010, 12:36 PM   #2 (permalink)
Member # 123988
http://www.classicent.com/jeep.php
Wolfghost is offline   Reply With Quote
Old 07-21-2010, 04:05 AM   #3 (permalink)
Member # 45290
thanks wolfghost but i could use the money i would spend on that stuff on tires or axles.
id rather just spend 200 on steel and cut it to fit, then weld it in.
Old 07-21-2010, 05:48 AM   #4 (permalink)
xPOLYMATHx
LucasFury's Avatar
Member # 113176
Send a message via AIM to LucasFury
..then do it. What's the hold up?
Measure, measure, cut, measure, measure, cut,weld.
Dirty deed done dirt cheap!
and custom leather belts and such too.
1979 FSJ Chief almost for sale. Inquire within.
LucasFury is offline   Reply With Quote
Old 07-21-2010, 06:32 AM   #5 (permalink)
Member # 45290
oh im gonna do it im just wondering what people are using for floor supports.
If no one answers im going to do it anyway and just wing it.
Im just not wanting to reinvent the wheel here.
this is a relativley simple fix that requires alot of work, I just want to make sure its done right.
Old 07-21-2010, 01:07 PM   #6 (permalink)
xPOLYMATHx
LucasFury's Avatar
Member # 113176
You don't need much in the way of floor support, especially if you end up tying your cage into your floor. I'd use something simple like angle iron or 2x4 tube cut in half lengthwise.
Old 07-21-2010, 02:56 PM   #7 (permalink)
Member # 74251
If your wanting to replace the C channel floor supports that tie the body to the body mounts, I believe they are 14ga. That is what I recall when I fabricated my own body reinforcements that tied the body to the frame mounts.
Standard flooring sheetmetal for the era of Jeep would be 18ga.
As already mentioned angle iron 14-16ga stitched to the bottom/ back side would support the sheet metal.
I don't know if this would work for you, maybe give you an idea but Quadratec sells floor patches for rusted out floor boards. Might save you some time in cutting, forming.
http://www.quadratec.com/products/22507_0100.htm
Wally
WallyP226 is offline   Reply With Quote
