Best Coil Springs for ROCKS? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-22-2010, 08:45 PM   #1 (permalink)
Member # 128015
I have a 98 TJ with JJ Control arms all around, Full Traction 3 link in the rear, with RE 3.5 springs & Bilstien shocks. It's a Short arm suspension.
I'm looking to replace my springs with something better suited for the rocks. I assume softer is better, so which spring is the best for for ROCKIN'?
Red Heep is offline   Reply With Quote
Old 08-23-2010, 12:55 PM   #2 (permalink)
Member # 74251
A little more info or the scope of what your looking for in regards to springs might help conjure more responses.
Whats wrong with the RE springs you currently have?
Have you weighed your Jeep to get a ball park figure of how much it weighs?
Wally
WallyP226 is offline   Reply With Quote
Old 08-23-2010, 01:32 PM   #3 (permalink)
Member # 128015
Well I didn't know how rough my jeep rode until I rode in my dad's new (used) jeep on the street. He has a clayton long arm kit and 5.5" Rock Krawler springs with brand new Skyjacker Nitro 8000's in the front and brand new 5100 Bilsteins in the rear.. Mine rides alot rougher (feel every bump in the road) on the street than his. His takes a speed bump on our street smoothly while mine bucks me out of my seat at the same speed.
Not sure on the weight of mine or his. I have a bolt on cage, tube front fenders, a crawler front bumper with no winch yet, a Rock Hard sport cage and a 3/16" Tummy tuck and a Warn rear bumper/tire carrier. Thats all the real extra weight I have over stock.
We haven't wheeled his yet (as he just picked it up this weekend) and I haven't wheeled my yet with the shock & JJ control arm upgrades. But judging by street manners, his is on a cloud and mine is on a gravel road. Just looking for opinions. I'm kinda a newb since I haven't wheeled all that much. Thanks.
Old 08-23-2010, 03:00 PM   #4 (permalink)
xPOLYMATHx
LucasFury's Avatar
Member # 113176
Send a message via AIM to LucasFury
Short arms ride like shit compared to long arms. Hell, I bet your 3.5" springs are closer to 5", being RE. Short arm geometry is good for about 4.
Dirty deed done dirt cheap!
and custom leather belts and such too.
1979 FSJ Chief almost for sale. Inquire within.
LucasFury is offline   Reply With Quote
Old 08-23-2010, 03:25 PM   #5 (permalink)
Member # 28875
X2 its your short arms.
95 XJ, f250 chromo'd D44 front, 35 spline 9inch rear, ARB's, 5:13's, 4.1 tcase, 37" KM2's
malsxj is offline   Reply With Quote
Old 08-23-2010, 03:29 PM   #6 (permalink)
Member # 128015
So I'm just SOL until I can afford a Long Arm kit 10 years from now? Nothing else will help?
Old 08-23-2010, 03:38 PM   #7 (permalink)
xPOLYMATHx
LucasFury's Avatar
Member # 113176
Get shorter springs..
Old 08-23-2010, 04:31 PM   #8 (permalink)
The Devils Trailboss
UCTJ's Avatar
Member # 51571
Check out Old Man Emu springs and shocks. I run 35s with a short arm and my jeep rides nice, it rides better with my current setup than when I got it with 32s and Doetsch shocks.
93 W250 CTD 5spd
97 TJ 60/14 Atlas 40" Maxxis 106" WB
Shawn
www.polyperformance.com
UCTJ is offline   Reply With Quote
Old 08-23-2010, 05:51 PM   #9 (permalink)
imped4now's Avatar
Member # 124275
With short arms, the lower the better. I run double JJ short lowers and front uppers with the triangulated RK setup in the rear. It has BDS 3" front springs and RC 2.5" progressive springs in the rear. I moved the coil buckets back so that the springs sit upright, which made a noticeable improvement in ride quality, as did outboarding the rear shock mounts. Run good shocks, low height, and good control arms (which you already have) and the ride should be very good.
imped4now is offline   Reply With Quote
Old 08-23-2010, 08:29 PM   #10 (permalink)
Member # 159343
Short arm suspension that rides well?
Keep it under 4", good shocks (outboarded if possible), relocate your springs (vertical) and check your air pressure.
You'll be surprised in the quality ride you can get with short arms.
Jeep02Apex is offline   Reply With Quote
Old 08-24-2010, 08:01 AM   #11 (permalink)
robi615's Avatar
Member # 127789
short long arm, around 3" or stock if you're willing to cut with a sawzall. The more horizontal you can get your links, the better the ride you will have. Short arms have their place, above a 4.5" lift its best to go long arm because at that height your short arms begin to have an extreme angle.
robi615 is offline   Reply With Quote
Old 08-24-2010, 10:26 AM   #12 (permalink)
Member # 128015
Let me clarify my intentions. I could care less about how it rides on the street. Its a jeep. I was using the street manners as a comparison because that's all I can do for now. I'm looking for the best performance out of my short arm. I have new Johnny joints all around and a full traction 3 link in the rear. I have new SA Bilstien 4" 5100's. Old RE 3.5 springs. Will a different spring improve the suspension at all? Thanks
Old 08-24-2010, 12:21 PM   #13 (permalink)
xPOLYMATHx
LucasFury's Avatar
Member # 113176
Definitely. If I were you, I'd use stock TJ springs and gain the clearence in the fenders.
Old 08-24-2010, 12:48 PM   #14 (permalink)
Member # 39079
As others have said, for a short-arm suspension go with short and soft springs. There is only so much movement you can get out of the shorter arms, so try to take advantage of it. With 5.5" of lift, your arms are running pretty high angles just sitting there.
Save your pennies and get longer arms if you want noticeable improvement.
Ryan
ElDirector is offline   Reply With Quote
