How much to narrow my dana 44? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-03-2010, 11:58 AM   #1 (permalink)
alex211's Avatar
Member # 142183
I have a chevy dana 44 housing I want to narrow around 4 inches total for my CJ. I have not decided to use the stock spring locations or to outboard them, so I can go either way. Should I cut 4 inches off the long side or something else? thanks
Shitbox xj 5 speed on 33s
alex211 is offline   Reply With Quote Quick reply to this message
Old 10-03-2010, 01:30 PM   #2 (permalink)
rockbuggy84's Avatar
Member # 45202
You should cut the 4" out of the long side, the cast perch in the diff says so. Or you could do 2" on each side but thats just a waste of time and money if you ask me.
rockbuggy84 is offline   Reply With Quote Quick reply to this message
Old 10-03-2010, 02:15 PM   #3 (permalink)
alex211's Avatar
Member # 142183
Ok, that's what I was thinking. I didn't know if I would run into any oil pan clearance issues by not out-boarding the springs. 4 inches off the long side would give me a 27.5 perch width which matches a CJ frame. I plan to daily drive this rig though so would it be top heavy around turns with the CJ perch width?
Also on my driver's side inner C it has an eccentric nut for the upper ball joint and the passenger side has the normal spanner nut. Is this factory? Should I get a inner c with a spanner nut to put on the tube when I narrow it?
Old 10-03-2010, 03:43 PM   #4 (permalink)
alex211's Avatar
Member # 142183
This is what I have on the driver's side, shouldn't this be a spanner nut?
Old 10-03-2010, 07:10 PM   #5 (permalink)
alex211's Avatar
Member # 142183
I cleaned the rust out of the inner c and there is a thin spanner nut in there, the driver's side must have had a camber issue. Hopefully I won't need to put one of the camber kits back in it when I get the front end together.
Old 10-03-2010, 09:36 PM   #6 (permalink)
Mr.N's Avatar
Member # 1635
I suggest keeping the axle shaft a stock length, from another application.
It makes finding and axle easier, and some times cheaper.
Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html
Mr.N is offline   Reply With Quote Quick reply to this message
Old 10-04-2010, 03:30 AM   #7 (permalink)
Member # 29517
AS stated above:
I believe if you cut 4" off of a Chevy full width 44, you can then run a stock long side inner Waggy 44 axle shaft.
Cost = pretty darn cheap.
Just grind on the weld to the inner c and hit it with a hammer until you see the hair line crack start. You can reset the caster/camber off of the other side when you cut the tube. I used a chop saw.
lockedandlowded is offline   Reply With Quote Quick reply to this message
Old 10-04-2010, 06:52 PM   #8 (permalink)
Member # 45202
where did you get this sheet? I would like to print out a copy thats clear
Old 10-04-2010, 07:52 PM   #9 (permalink)
Member # 114505
From his website!
Tim
gssfc is offline   Reply With Quote Quick reply to this message
Old 10-04-2010, 09:15 PM   #10 (permalink)
Mr.N's Avatar
Member # 1635
Originally Posted by gssfc View Post
From his website!
Tim
Tim is right, I took the time to pull info from books, and pdf's.
I've the excel copy, but only share the picture. If you don't like it, make your own...
Then again, the picture is clear, it's the forum software that messes it up.
FYI, this is the small list, with just 297 sized u-joints for Dana 44's.
Save this Link -> http://77cj.littlekeylime.com/Spicer/graph/Dana44_Front_Axle_shafts_Mr.N_shortside_.GIF
Old 10-05-2010, 12:31 PM   #11 (permalink)
Member # 45202
Thanks, saved it!
Old 10-05-2010, 12:48 PM   #12 (permalink)
alex211's Avatar
Member # 142183
It looks like a driver side drop waggy 44 passenger innner axle is what I need. It is exactly 4 inches shorter than my factory long side axle.
Anyone have any opinion on high steer arms? I was planning on runnig a tie rod off the knuckles in the factory location and the drag link using TREs to a high steer arm on the passenger side. My steering box is off a J20, will GM 1 ton tie rod ends work with its taper?
Old 10-05-2010, 12:51 PM   #13 (permalink)
Member # 100284
NOT at all. Keep the width, if you wheel you will NOT regret it. If your not changing the rear axle get wheel spacers. Seriously!
Silver '06 'X'
"The Pirate Boat!":skull:
KennyTJ is offline   Reply With Quote Quick reply to this message
Old 10-05-2010, 01:01 PM   #14 (permalink)
alex211's Avatar
Member # 142183
Aiming for this look, I need to be able to drive it every day.
Old 10-05-2010, 04:06 PM   #15 (permalink)
Mr.N's Avatar
Member # 1635
They make wide flares... and rims with a lot of off set...
Old 10-05-2010, 04:30 PM   #16 (permalink)
alex211's Avatar
Member # 142183
Well ...
No turning back now.
Old 10-05-2010, 04:57 PM   #17 (permalink)
Member # 80076
looks good, just narrowed my 44.....it's easy to do, just take your time and read pirate
You were born an original, Don't die a copy
fLaT TiRe is offline   Reply With Quote Quick reply to this message
Old 10-05-2010, 05:08 PM   #18 (permalink)
alex211's Avatar
Member # 142183
It would have been a real bitch to remove the weld without the plasma cutter. Now I'm off to sears to buy an angle finder so I can get the inner c on correctly.
Should I throw the inner c in the oven for a while before I try to put it on?
Old 10-06-2010, 09:12 AM   #19 (permalink)
CSP
Member # 1533
I put mine in the oven before installing. It definitely helps but you still gotta move fast.
I cut right through my weld and the tube instead of trying to grind the weld and remove the inner c. It was much easier then to just remove the small piece of tube that remained in the 'c'.
CSP is offline   Reply With Quote Quick reply to this message
Old 10-06-2010, 12:23 PM   #20 (permalink)
Member # 80076
the digital angle finder from harbor freight worked good for me...check it out if you didn't buy one from sears yet
Old 10-06-2010, 09:21 PM   #21 (permalink)
alex211's Avatar
Member # 142183
I put the inner c on using a sears angle finder and a level, the caster is dead on. I didn't heat the inner c, it went right on with some taps from a hammer. I made the other side level and then matched it on the driver's side, it should be really close.
Old 10-08-2010, 09:31 PM   #22 (permalink)
alex211's Avatar
Member # 142183
Inner C is welded on.
