1993 LT1 Coolant Hose Routing - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-20-2010, 05:53 PM   #1 (permalink)
Member # 166607
I'm trying to plumb in the coolant system, anyone have a diagram of where all these hoses go? I have hoses that go to the intake, heads, water pump. I know for sure I have the upper and lower main hoses right, but the rest I'm not too sure of. Also, where do the heater hoses come from? I have two open ports on the right of the water pump, I'm thinking these are probably them, but any help here? I've already done all my searching.
alaskanbadfish is offline   Reply With Quote Quick reply to this message
Old 10-21-2010, 08:33 PM   #2 (permalink)
Member # 166607
bump
Old 10-29-2010, 04:09 PM   #3 (permalink)
Member # 166443
well this is really like two weeks old and if you didnt find your answer on google i will help out a little bit.
there is one outlet by the temp sensor. that is the oil cooler. goes threw to the oil filter and then back to the radiator. the two on the passenger side is the heater core. the top one has a splice and it goes to the bottom of the throttle body. you can by pass that if you want. the two coolant passages on the bottom of the throttle body i mean. again i can get pictures if you need too. hope this helps if not done already
cleckner04 is offline   Reply With Quote Quick reply to this message
