Front Axle Help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-23-2010, 02:51 PM   #1 (permalink)
Member # 153931
Front Axle Help
Hey, I've got a 88 cherokee with the stock d30 front axle. It's got the vacuum powered 4wd engagement system. Can I eliminate that by swapping out the 2 piece shaft with a solid shaft from a TJ? Or does anyone know where I can buy a solid axle shaft? Thanks
Ethan is offline   Reply With Quote
Old 10-23-2010, 03:17 PM   #2 (permalink)
Member # 19323
Yes you can, you will need the inner axle seal for it and I would go ahead and get the drivers side also so that you will get the larger 297 ujoints at the same time, I do not know the part numbers for the seal as I never bothered to upgrade a D-30
Mud River Motorsports
RCrocs Class 3 Team #304
Fullsizexj is offline   Reply With Quote
Old 10-23-2010, 04:15 PM   #3 (permalink)
nismo5's Avatar
Member # 153869
http://www.stu-offroad.com/axle/yjd3...jconvert-1.htm
its the same thing
nismo5 is offline   Reply With Quote
Old 10-24-2010, 02:11 AM   #4 (permalink)
ONEtonXJ's Avatar
Member # 145633
solid shafts came in XJ's too jackass
"Tater2" - '91 2 door XJ. 4.0, AW4, 231/300 doubler, GM 60/70HD, 6.17s, ARB's & 4Ds
ONEtonXJ is offline   Reply With Quote
Old 10-24-2010, 02:24 AM   #5 (permalink)
Member # 19323
88 XJ's came with the disconnect 3 peice shaft on the Passengerside, you should think before you type
Old 10-24-2010, 06:45 AM   #6 (permalink)
Moderator
ashmanjeepXJ's Avatar
Member # 10249
Non disconnect shafts came in newer XJs, just like the TJ shaft he's looking at.
ashmanjeepXJ is offline   Reply With Quote
Old 10-24-2010, 07:58 AM   #7 (permalink)
Member # 19323
yup, that is correct, they also came with the larger 297 ujoint so he should nab both axle shafts as the 88 came with a smaller ujoint
Old 10-24-2010, 03:32 PM   #8 (permalink)
Member # 153931
Hey, thanks guys, good info
Old 10-24-2010, 03:50 PM   #9 (permalink)
Wild Hare's Avatar
Member # 75473
WOW, completely uncalled for
lead or follow, it doesn't matter. Just get the F@#$ out of my way!
Wild Hare is offline   Reply With Quote
Old 10-24-2010, 03:59 PM   #10 (permalink)
spot me? mydfghgfff!
gtxracer's Avatar
Member # 25303
Don't bother with a block off kit, get a SealsIt seal and be done with it. That's what I did and it only requires you to pull the carrier and slip in the seal with some silicone - no pressing in a seal and finding which one goes in your specific housing. Trust me, I tried 5 different seals and SealsIt was the only one that actually fit and seals twice.
97 TJ 4.0/np435/d300/3link/4link in progress
Ultimate Wrangler Build Ups and Swaps Thread
Builds, Swaps, Axles, Engines, Turbos, Diesels, Suspensions, Fab, and more!
Now incorporating a CJ and Willys section, post your tech and builds!
gtxracer is offline   Reply With Quote
Old 10-25-2010, 10:26 AM   #11 (permalink)
Member # 153931
so no need to replace the axle shaft? does the sealsit fix the vacuum problem?
Old 10-25-2010, 10:32 AM   #12 (permalink)
gtxracer's Avatar
Member # 25303
Use any 1 piece axle shaft for a D30 from a TJ, XJ, etc. A few guys have made the vacuum system into a posi lock, you may want to look at that too. The SealsIt seal allows you to use any 1 piece shaft and is better than any "kit". I used a kit and other seals first and they were horrible, then got a SealsIt and couldn't be happier. Check out my "grandmas boy" build by searching under my user name, I went into some detail about all this in that build.
Old 10-25-2010, 10:33 AM   #13 (permalink)
Member # 153931
alrighty, sweet thanks
