?s about lowering my tj - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-15-2010, 03:54 PM   #1 (permalink)
Member # 116329
i have a 98' 4.0l tj w/a rubicon 4 1/2" sf short arm kit, 1" body lift, aa sye, dc drive shaft, on 35's and a 8.8 rear. i want to take the 4 1/2" springs out and replace them w/ 2" or 2 1/2" springs. will i end up having to shorten my drive shaft or make any othe mods if i do this?
mondols1 is offline   Reply With Quote
Old 11-15-2010, 08:57 PM   #2 (permalink)
Hotpeper's Avatar
Member # 150259
Best bet...
measure your drive shaft now, lower the jeep, remeasure.
You might be within a reasonable tolerance.
A drive shaft shop can cut it down for you pretty cheaply(less than the cost of a new one for sure)
Hotpeper is offline   Reply With Quote
Old 11-17-2010, 09:10 PM   #3 (permalink)
Member # 116329
tks, i need to locate some springs then get to work!
Old 11-18-2010, 06:06 PM   #4 (permalink)
Member # 156136
As long as you are only shortening a shaft its pretty damn cheap, it wont need shortened much though if it does....
cottonmouth is offline   Reply With Quote
Old 11-18-2010, 08:00 PM   #5 (permalink)
Member # 99650
get a tummy tuck
matt linderkamp is offline   Reply With Quote
Old 11-19-2010, 01:15 AM   #6 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
Originally Posted by matt linderkamp View Post
get a tummy tuck
x2
primate60 is offline   Reply With Quote
Old 11-20-2010, 12:58 AM   #7 (permalink)
Member # 111426
Why are you lowering it? Are the springs wore out that're on it? I'd get rid of the body lift. It's the cheap thing to do and easy to.
turbohaulic is offline   Reply With Quote
Old 11-20-2010, 09:10 AM   #8 (permalink)
Member # 17986
It might work. The best bet would be to raise your belly up, or even see about moving your axle back the inch or so needed.
You're not a Jeep guy, are you?
98TJ 5.9/46RE/D300 RAC
Pansy-Ass Offroad
pcoplin is offline   Reply With Quote
Old 11-20-2010, 09:44 AM   #9 (permalink)
hurleygo3's Avatar
Member # 80862
You will not need to do anything with your drive shaft. The travel of the shaft will not change. It is still traveling on the same radius.
If you were changing the arms than you would have to mess with the shaft.
The springs will not effect the drive shaft.
www.facebook.com/EckoMotorsports
www.partsmike.com
www.savvyoffroad.com
www.trail-gear.com
hurleygo3 is offline   Reply With Quote
Old 11-20-2010, 02:45 PM   #10 (permalink)
Member # 111426
Nope but I've worked on em more than my toy My old man is a jeep guy.
Old 11-20-2010, 05:08 PM   #11 (permalink)
Newbie
Laxnyj18's Avatar
Member # 138476
x2 on ditching the body lift, unless you go with a TT that needs it.
Then I would make yourself a TT, lower it, then measure your shaft and see if it needs it. Which it shouldn't.
I am not sure what your control arms though, you may need a shorter set of them also...
Laxnyj18 is offline   Reply With Quote
