Member # 88919
I screwed up and can't find the answer I'm looking for in search.
I was reaming out the steering knuckles on the Dana 30 in my XJ for 1 ton tie rods and the reamer caught a piece of metal weird and yanked the drill from my hand, wallowing out the hole pretty bad. The tie rod bottoms out because the hole is too big now, so I was wondering if I could fill in the hole completely and re-drill/ream out again. I have a Miller 211 wire feed with shielding gas and that's it for what I have to weld with. If worse comes to worse, I can always replace the knuckles but this XJ is my daily so I'm trying to get it back on the road ASAP. Any suggestions? I've seen the Ballistic fab tapered insert, but I don't want to drill a 1" hole in an already small tie rod arm.
[COLOR="Lime"][I]At 1300rpm's would you rather have 10 extra hp or 10 extra lb-ft of torque?[/I][/COLOR] |
#3 (permalink) | |
Member # 4375
Clean it up a bit and install the tie rod. I've fixed at least 50 this way and never had a single failure or loosening. If you weld it with your Mig, you will ruin the knuckle and your tapered reamer.
I am an official member of the "I saw Dave Cole get run over by a rock buggy" club. |
#4 (permalink) | |
Member # 88919
Member # 4375
Do NOT weld it in and then try to taper it. You will ruin your tapered reamer. Ream it first to fit and then weld it in. Plus that stops you, being the drill wizard that you are, from fucking it up again.
Member # 133593
just drill it straight through and go to heims
"The American people sleep peaceably in their beds at night because US Soldiers stand ready to do violence on their behalf" 2000 XJ Classic: 4.5" lift, 4.56's, Alum Beadlocks, 35's, and all the other soccer mom add-ons 1948 Willys CJ2a: stock for now 2000 Audi S4 Stage II |
Member # 4375
Oh Yeah, because a straight hole in soft iron always works well to keep your bolts tight.
Member # 3511
Easiest and fastest solution is to just replace the knuckle. Drill it before you install it. Around here it would be pretty easy to come up with a free D30 knuckle.
Chuck P The clowns'? Oh, yeah, the clowns. We fight them too — entire armies, spilling out of Volkswagons. We do our best to fight them off, but they keep sending 'em in! www.oldjeep.com |
