Member # 176635
Sup guys I am new to the forum and need some assistance.
First let me give you the specs on my Jeep - 1993 Jeep YJ Inline 6 4.0 Automatic Im having issues with intermittent starts on my Jeep. There will times that my Jeep has a hard time starting. I can go a few days with no problems then out of the blue it will not start. Engine will just crank over. I just purchased the Jeep and according to previous owner he said that it was the ICM. Owner stated that Ignition Coil was replaced, Crank Sensor was replaced as well and pluggs. I have no issues with powerloss or idles. Just need some advice on what it could be. Also would I be able to use a Cherokee CPU on my YJ? Thanks in advance |
Member # 72257
So...Have you replaced the ignition control module as that is what the previous owner said it was?
Cause that sounds like your problem..
I drive the fastest barbecue on 4 wheels... |
#3 (permalink) | |
Member # 176635
Sorry this is my first Jeep so Im trying to learn the ins and outs of it. |
I'm trying to remember where that damn module is. I think its either on the firewall, or on the inner fender. It should have a big plastic cover. Once you find it, heres a low tech trouble shooting method. With the engine running, give it a solid hit with the butt of your hand. If the engine stumbles, stalls, or shuts down, thats your problem. I know it sounds hillbilly as hell, but it works in a pinch.
#5 (permalink) | |
Member # 176635
When I did my search about the ICM I was always seeing this Image :http://www.quadratec.com/Assets/Images/5545/5545-th.jpg |
#9 (permalink) | |
Member # 176635
Now Im running into some other issues. 2 days ago my Jeep conked out on me, I was using it all day and then just wouldnt start after I went to a tire shop. It wasnt getting any spark going to the pluggs. First - I changed the crank sensor, still didnt do anything Second - I changed the coil module, and that seemed to work Jeep started right up and let it run for a few minutes then tried to start it again, so far so good. But then when I was heading out to work I started the Jeep and its now misfiring. Third - Changed the Plugg Wires cus they were arching, Jeep still misfiring. Took out pluggs and looked fouled, cleaned them up and Jeep started right up with no issues. Took it for a 20min drive and even made a few stops, so far so good. Now I just tried to start it and same thing again, its misfiring . Idk if pluggs are bad already, but cap and rotor are still ok.
New Beginnings
Member # 99513
Run a tank of 91 octane with injector cleaner through your system. Injectors could be clogged up.
Its a 93, Its almost 20 years old! Things to do to these motors for maintence; Cap Rotor Plugs Plug Wires Fuel Filter Injector cleaner or flush fuel system Check you FPR on the fuel rail Check Fuel pressure In Accordance with Manuel(Go get a Chiltons manual NOW!) After this much, then you start diving into sensors and Modules which means you start to spend $$$$$ And MY1stNicejeep is correct. I tend to find the People at the Stealership are FAWKING DUMB AS SH!T !!! Get away from the dealer. They are there to rob all your money. ![]() No ICM on a 1993 YJ. But you do have a PCM.
My jeep is a hotrod! /forum/jeep-hardcore-tech/658004-going-against-odds.html ![]() NEW BEGINNINGS: /forum/general-4x4-discussion/971511-jealle-o-cigano.html Last edited by jpfrk2001; 01-05-2011 at 08:54 AM. |
New Beginnings
Member # 99513
I just looked at my Schematics
Automatic Idle Speed Motor So its not a really referred to a ICM, but I think its the closest thing the dealer may be talking about It is directly wired going to the PCM
My jeep is a hotrod! http://www.pirate4x4.com/forum/showthread.php?t=658004 ![]() NEW BEGINNINGS: http://www.pirate4x4.com/forum/showthread.php?t=971511 Last edited by jpfrk2001; 01-05-2011 at 08:53 AM. |
#12 (permalink) |
Member # 65637
If your spark is randomally quitting I would try the CPS sensor.Very simple to change.Manual and auto CPS are the same.Borrow one from a friend if you dont want to buy new.Takes less than 5 mins to swap.
EDIT:Just read you swapped it.Are you sure it was good?Sure sounds like the CPS
Jeep with Things and Stuff Last edited by My1stNiceJeep; 01-05-2011 at 09:20 AM. |
#13 (permalink) |
New Beginnings
Member # 99513
FAWK!!
Now my jeep just quit running on me!! FAWK!!
My jeep is a hotrod! http://www.pirate4x4.com/forum/showthread.php?t=658004 ![]() NEW BEGINNINGS: http://www.pirate4x4.com/forum/showthread.php?t=971511 |
#14 (permalink) |
Member # 176635
Ok so I replaced the Cap and Rotor., but still having same issues.
Verified that its getting fuel. All wires have spark in them, pluggs are not fouling. Still sounds like its misfiring, even verified wires were in correct firing sequence. Im thinking that my PCM may be bad. Last edited by ANONYMUS; 01-06-2011 at 07:38 PM. |
#15 (permalink) |
New Beginnings
Member # 99513
TPS now?
My jeep is a hotrod! http://www.pirate4x4.com/forum/showthread.php?t=658004 ![]() NEW BEGINNINGS: http://www.pirate4x4.com/forum/showthread.php?t=971511 Last edited by jpfrk2001; 01-07-2011 at 08:49 AM. |
