Lost
Member # 6426
One Ton rear Axle Options - 68 - 69" WMS
I'm searching for best options. Seems like widening my 60 isn't a good way to go.
I need to find a rear axle 68-69" wide that will hold up to 42's (or can be built for them). Most 14 bolts seem narrower than this. What are some axle that fall into this category?
Couple of YJ's without leafs. |
#2 (permalink) | |
Member # 116340
If its a little narrower then just make up the width with the offset of the wheels? |
Member # 86508
If you already have a 60 that is narrowed you can always get a new one and swap gears and such. Only thing you would need to replace is shafts or just run the stock ones from the new 60.
14b are right around 67. trucks have a narrower rear axle for a reason. helps it to track better on road |
Member # 88919
I'd go with a 14 bolt. Like said above, it's 67" right out of the box and if you're trying to match a front axle that's 68-69" wide up front, you'll be better off with a slightly narrower rear axle. 0.5"-1" narrower rear sounds perfect to me, and you wont be able to notice the width differences - especially with 42" tires. Try to find one with a factory Detroit and you're golden.
The only downside to the 14 bolt compared to, say a built D60, is the gear ratio "limitations". If you have something crazy like 6.17's or deeper the 14 bolt wont be able to accommodate.
[COLOR="Lime"][I]At 1300rpm's would you rather have 10 extra hp or 10 extra lb-ft of torque?[/I][/COLOR] |
Lost
Member # 6426
Front is 69.25 - Ideal rear would be 68.5 for me.
I'm trying to match widths to allow clearance of the rear tires and keep the same offset wheels all the way around. I can get spacers for the rear of the 60, but am looking at the cost by the time I bore the hubs, go 35 spl Cro-moly, a 35 spl locker and disc brakes...so it seems to be cheaper to just go straight to a newer axle with at least the brakes and large bore hubs and sell off my 60. What are the widths of late model disc brake Chevy and dodge axles?
Member # 69047
It isn't worth a bunch of trouble to change your track width 1 or 1.5 inches. As others have said, you want the rear axle to be narrower than the front anyway. If you need more clearance in the rear then just use wheels will a little less backspacing. You can still run the same backspacing in the front. Changing your backspacing by 1/2 or 3/4" is an easier option. Just run a 14 bolt and whatever backspacing you need to get the overall width you want. You are probably going to want beadlocks anyway, so spend your money on those and get a cheap 14 bolt.
#8 (permalink) | |
Lost
Member # 6426
