Losing Brake Fluid - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-31-2011, 12:00 PM   #1 (permalink)
Member # 155322
Losing Brake Fluid
I've bought a used 2003 TJ and seem to be losing about a 4oz of brake fluid a week. However, I do not see any signs of it leaking, but it's really hard to tell since my garage floor and jeep are both a mess from the winter weather. Are there certain things that the TJ is prone to leaks that I should check first? I have a soft parking brake too, it barely holds, could this be a related problem.
highsidezx12r is offline   Reply With Quote
Old 01-31-2011, 12:07 PM   #2 (permalink)
LeadfootCJ7's Avatar
Member # 85264
Send a message via AIM to LeadfootCJ7
I would look into the rear brakes then. They could be coated with the leaking fluid keeping the parking brake from being able to hold.
81 CJ7 258/NV4500/Dana 300 4" Skyjacker lift & 1" BL; 4.10 gears, Detroit lockers, Warn M8000
LeadfootCJ7 is offline   Reply With Quote
Old 01-31-2011, 12:23 PM   #3 (permalink)
Ho Shorts's Avatar
Member # 109328
This is a longshot, but I have seen this before on a Jeep. IF you search all 4 wheels, brake lines, etc. and still can't find any leaks pull your master cylinder. I have seen one that the rear seal was bad and it would expel fluid into the brake booster which would in turn get sucked into the intake on the engine and get burnt up and dissappear. This was HELL to diagnose and took a while for me to figure out. All you have to do is pull it and you will find traces of fluid inside the booster if it is happening.
It's much more likely just a leaking caliper or something though.
Ho Shorts is offline   Reply With Quote
Old 02-01-2011, 05:45 AM   #4 (permalink)
Member # 4375
Have you ever seen a leaking caliper on a TJ? I've seen brake lines, wheel cylinders, seals in masters, bent banjo bolts, and damaged braided and rubber flex hoses leak, but never a caliper.
Also if the master is leaking back into the booster, you get to replace both of them. Brake fluid ruins the diaphragms.
I am an official member of the "I saw Dave Cole get run over by a rock buggy" club.
mrblaine is offline   Reply With Quote
Old 02-01-2011, 05:47 AM   #5 (permalink)
Member # 4375
It seems counterintuitive but typically rear brake shoe contamination by gear oil or brake fluid makes them lock up harder. Not sure why, but it just works that way.
Old 02-01-2011, 09:31 AM   #6 (permalink)
Member # 155322
Thanks for the suggestions guys. When it gets above 0 here or the wind stops blowing then I think I'll start tearing down the rear first and work my way to the front.
Old 02-01-2011, 09:42 AM   #7 (permalink)
djelliott916's Avatar
Member # 134532
X2
And sometimes when you hit the brakes, you get a little puff of white smoke out the tailpipe.
djelliott916 is offline   Reply With Quote
Old 02-22-2011, 01:33 PM   #8 (permalink)
Member # 155322
It finally dried up around here last week, and it was dead obvious then where the leak was from. The right rear wheel cylinder was bad and leaking like crazy. It's all good now though. Thanks for the info on the master cylinder, I will keep it in mind if I notice any other problems later on.
