Gearing options - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-01-2011, 04:55 PM   #1 (permalink)
Member # 131296
Gearing options
Sorry if I posted this in the wrong section but I don't know where I should put it, feel free to move it if it's not in the right spot,
Anyway,
I'm building my diffs right now, well starting to... And I'm gonna be ordering my gears, I'm not too sure what I should be running for gears so I don't kill my motor but can still do 80-100km/hr on the highway,
What I'm running right now is
4.0L,AW4,np231 with teraflex 4.1 kit, hpD60 front and shaved,disk braked 14 bolt rear,
Tire size, I was thinking 40" tires,
I have a gear calculator on my phone and was thinking I should run 4.88 gears or 5.13,
What I'm worries about with 4.88's is being under powered, and what I'm also worried about is my rpms being too high on the highway with 5.13's anyone shine some light on this for me before I go and buy the wrong gears for my jeep?
Thank you
Nick
86 cj-5 frame, 76 cj-5 body, put together on 35" krawlers, 360v8,np435,d300 twin sticked
whitetrashxj is offline   Reply With Quote
Old 03-01-2011, 05:39 PM   #2 (permalink)
Member # 88919
There's more to it than highway rpm's. It's highway load. 1 tons and 40+ tires weight a lot more. You NEED to turn those extra revs to keep the engine happy so you're not sucking down gas. 5.13's all the way, especially with the 4.0L. At 100kmh you're only going to be turning 1870 rpm's and that's hardly chugging along on the highway with 5.13's. Expect to downshift any time you hit a slight incline.
Make sure to install a great transmission cooler.
[COLOR="Lime"][I]At 1300rpm's would you rather have 10 extra hp or 10 extra lb-ft of torque?[/I][/COLOR]
Rinkrat456 is offline   Reply With Quote
Old 03-01-2011, 06:49 PM   #3 (permalink)
POS YJ's Avatar
Member # 152085
You WILL NOT be happy with 4.88's!! Go 5.13's, if not deeper. The 4.0 will run fine at 3,000rpm on the freeway if that's what you're worried about.
POS YJ is offline   Reply With Quote
Old 03-01-2011, 09:52 PM   #4 (permalink)
Member # 166616
40's? I say 5.38's. That thing is gonna be a pig.
Justdhutch is offline   Reply With Quote
Old 03-01-2011, 10:36 PM   #5 (permalink)
Ho Shorts's Avatar
Member # 109328
I ran 4.88's with 38" on my XJ and it was on the borderline of being geared too high. 40's DEFINATELY go 5.13 if not 5.38
Ho Shorts is offline   Reply With Quote
Old 03-02-2011, 07:49 AM   #6 (permalink)
Member # 118546
My vote is 5.38's
james@bluetorchfab is offline   Reply With Quote
Old 03-02-2011, 03:42 PM   #7 (permalink)
Member # 108872
Send a message via AIM to MonsterSeven Send a message via Yahoo to MonsterSeven
if you have come this far, what makes you think you are going to stop at 40s? do it once, and do it right, the first time. 5.86s.
*98 RHD TJ: swapped 4.0L/AX-15/Dana 300, 4.88, AEV 3", LP9"/S88, Grizzly/Detroit, OTK steering, 35" muds... 84:1.
*85 CJ-7: GM350/NV4500/D300, SOA on Wags, LP44/LP9", Aussies, 37" MT/Rs, Staun beadlocks, hi-steer, 110:1... in pieces.
MonsterSeven is online now   Reply With Quote
Old 03-02-2011, 03:59 PM   #8 (permalink)
Member # 166616
He can't. 5.38 is as big as they go for the 14b.
Atleast I couldn't find any bigger. If they make 5.86's now I'm gonna be pissed because I just finished my install of 5.38's.
Old 03-02-2011, 04:03 PM   #9 (permalink)
Member # 108872
time to find a different rear axle then.
in that case, 5.38s.
Old 03-02-2011, 04:21 PM   #10 (permalink)
Member # 166616
If you want a cheap, very strong axle, with disc brakes, you can't go wrong with a 14b. I'm into mine for under $500
14b -$50
5.38's -$150
Disc brake swap -$240 (and I could've went cheaper but got all new parts)
Old 03-02-2011, 04:29 PM   #11 (permalink)
New Beginnings
jpfrk2001's Avatar
Member # 99513
I have the EXACT drivetrain combo and tire size on my YJ. Go 5.38's Thats what I run
2800 RPM and Im turning around 75 on the Hwy no problem
jpfrk2001 is offline   Reply With Quote
