transmission help!! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-16-2011, 03:57 PM   #1 (permalink)
Member # 185008
transmission help!!
i have an 88 yj with a stock tranny and transfer case anyone know what i need to do to get a set of axels with 4;10's to work with the tranny or do i have to replace it has 304 gears now
shawnconnors is offline   Reply With Quote
Old 03-16-2011, 08:12 PM   #2 (permalink)
flatblack51's Avatar
Member # 121033
wow...... you can run what ever axles you want any gear ratio you want! or tell me what gears you want and the axles you have and I can get you a fat deal I might even have master installs for them too. then take it to a shop and have them re gear what you have
89 YJ but not really back halved!?!350 5.7L 4L60E D60 14B(shaved)5.13 39" BFG Baja projects atlas 4spV2 ADS coilovers and fox bumps at the corners!
BOMTEC Racing 4476 jimmy's 4x4 support team
Torchmate2x4 cutting your stuff for dirt cheap!PM for quotes!
flatblack51 is offline   Reply With Quote
Old 03-17-2011, 02:20 AM   #3 (permalink)
Member # 147031
All you need is 2 axles with 4.10's... Easy way would be bolt in axles, harder way would include a welder.
You do not need to replace the tranny to regear the axles
Fudpucker is offline   Reply With Quote
Old 03-22-2011, 09:51 AM   #4 (permalink)
Member # 185008
a friend of mine wanted to sell me a ford 8.8 and a d30 with 4 10s i just wasnt srure if the tranny and t case would work its my first jeep build lol
Old 03-22-2011, 10:25 AM   #5 (permalink)
CSP
Member # 1533
You realize that there's a driveshaft between the tcase and the axles, right?
In other words the axle doesn't attach to either the tcase or transmission.
If your YJ has a manual transmission, it is a POS, but that's a completely different subject altogether.
CSP is offline   Reply With Quote
Old 03-22-2011, 01:59 PM   #6 (permalink)
Member # 185008
yes i realize that i just wasnt shure if the gearing in my tranny and t case had anything to do with the axel gearing
