I know this question is going to cause some flaming towards me but I'm asking this question on pirate because this is the best source for answers on 4x4 issues and I've searched with no gain. Anyways, I recently installed a SYE and CV ds on my jeep and I noticed after traveling roughly 15 miles 10 highway that my transfer case was extremely hot as was the yoke and upper part of my ds. I first thought my ds was binding but that wasn't the case and it shifts smoothly as well.
I'm about to open the transfer case up and see if I find anything but I wanted to see if this is normal, I'm guessing its not but who knows.
Spec of jeep '03 NP231J, rigged rudge SYE with used CV unsure of company, pinion angle is 2 degrees off from DS if that helps
Mine gets hot too. My yoke nut was loose for a while, so I was blaming it on a bearing issue, but its not even a tapered bearing in there, so that must not be it. In for any answers or flaming that may occur.
not sure of your drivshaft angles--but on a cv style the rear yoke needs no angle and should point at the transfer case yoke, a degree or two is still good. cv joints have there limits also, too much angle or a dry centering ball will cause a LOT of heat. could just need greasing (some can and some cant)
There is that oil slinger that goes over the output shaft. If you didn't get the little feed line on right it wouldn't lubricate hence heat. Just an idea, but it does offer a viable explanation.
Well I took the t-case apart found out the oil feeder tube wasn't fully connected so I fixed that and greased the CV joint. But even after all that my heating problem is still there . Any other suggestions guys
What do you mean by "hot"? ...like it is uncomfortable to touch or it's so hot it will burn your hand if you touch it? I don't have an exact temperature to give you, but it's normal for it to get pretty hot.
You ARE aware that the t-case is sitting DIRECTLY beside a 1600 degree catalytic converter right?
If the oil tube is in there, there are no noises, and it shifts fine, 99% likely there's nothing wrong with it.
They normally are pretty damn warm to the touch from what I remember, but I recall having some damn toasty fluid pour onto me when I replaced a tailshaft seal on a customer's TJ that they had just driven for about 30 min to get there.
Your most likely correct Flatlander. I just wanted to make sure because something didn't seem right with the heat of the CV joint of the driveshaft but thats most likely heat transfered from the yoke
Thanks guys for the suggestion lets hope its just me being paranoid
