Clutch is spongy, transmission wont shift - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-14-2011, 12:29 AM   #1 (permalink)
Member # 190460
Thumbs down Clutch is spongy, transmission wont shift
i have a 1990 YJ. After a drive from northern LA to OC and parked at the hotel, when i came back to drive it out the transmission would not shift.
the Clutch is all the way down. i checked for leak i couldnt find any. nothing below the dash and no leaks to be found under the jeep.
Checked the transmission fluid it was low about 3 quartz (huge). topped if off ran it for a while stationary no leaks.
Now the clutch wont engage or disengage. the transmission would shift fine when the engine is off but not when its on.
when i position it in 1st with clutch all the way in, the jeep would jump forward with little gas it would run forward fine without any noise.
Same thing in reverse, all gears work fine but it doesnt seem like the clutch is operating correctly!
i am not a subject matter expert, in case you have something in mind please detail it so i could take baby steps processing it and performing the repairs.
any pics showing the parts being discussed would be greatly appreciated.
Thanks all!
zawarwar is offline   Reply With Quote
Old 05-14-2011, 12:56 PM   #2 (permalink)
bluedeval03's Avatar
Member # 189306
Send a message via Yahoo to bluedeval03
Thanks all!
can't get easier to follow than this link.
http://www.clarks-garage.com/shop-manual/ts-04.htm
good luck
bluedeval03 is offline   Reply With Quote
Old 05-14-2011, 06:54 PM   #3 (permalink)
Member # 190460
please dont flame me too hard, is this the system on a Jeey YJ 1990?. i tried to follow the hoses from reservoir but i couldnt see anything going to the break reservoir. please let me know if i am right or wrong. the diagram threw me off!
944 CLUTCH HYDRAULIC SYSTEM
Old 05-14-2011, 06:56 PM   #4 (permalink)
Member # 190460
when looking at the reservoir, i can only see one hose going straight down to the master slave, the res is attached to the firewall.
top of the reservoir has a cap which is different than the one drawn in the diagram?
Old 05-14-2011, 07:51 PM   #5 (permalink)
Member # 190460
Disregard my previous posts. i just noticed the 944 is a Porsche. what a dummy i am?
sorry !!!!!!!!!!!!
thanks for the info!
Old 05-14-2011, 07:52 PM   #6 (permalink)
Member # 189306
no is not the exact same, but the principle of the diagram is. Instead of having the brake system also furnish the fluid, it has its own reservoir. the '90 model also uses an internal slave cylinder instead of an external.
You should be able to follow the rest of the info in link to help you track the problem.
Old 05-14-2011, 09:13 PM   #7 (permalink)
Member # 190460
thank you! i am going to start working on it tomorrow morning. first order of business will be gravity bleeding since i do not have help.
if that is not good enough should i go ahead and replace the master slave or what do you suggest?
Old 06-16-2011, 06:08 PM   #8 (permalink)
Member # 189306
did you ever figure it out??
