81 CJ7 brake assembly - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-16-2011, 04:59 PM   #1 (permalink)
sammyg's Avatar
Member # 98177
Front brake assembly, CJ7. I took it apart, got new pads and calipers, and for the life of me, I can't figure out how it goes back together. I have one spare clip, and I don't know where it goes. I understand where the long hair pin goes. Does anyone have a picture or a breakdown?
I did search
TIA
I don't always show my signature. But when I do, it's in this area.
sammyg is offline   Reply With Quote
Old 05-16-2011, 06:51 PM   #2 (permalink)
Member # 74251
What year? My 1985, doesn't have clips.
The brake pads slide onto the rails, via the slots in the ends of the brake pad.
The caliper, slides up under the top rail, and hinges down at the bottom.
A 7mm hex allen wrench is used to tighten and loosen the caliper pin/ bolts on the inside.
Wally
WallyP226 is offline   Reply With Quote
Old 05-16-2011, 07:33 PM   #3 (permalink)
sammyg's Avatar
Member # 98177
thanks Wally. Guess my new calipers came with some extra parts? Mine's an 81 axle, but it's in the 47 Willys now.
I think I got it assembled, but I'll be damned, I can't fit my wheels over the discs. Could have sworn the rims being off an 78 would have fit....
Old 05-16-2011, 07:34 PM   #4 (permalink)
sammyg's Avatar
Member # 98177
Wait a sec, is that 7mm on the top or bottom of the bracket? Maybe I have my brackets on upside down. These brackets bolt on with 2 7/16ths bolts to the knuckles, btw.
Old 05-16-2011, 07:45 PM   #5 (permalink)
Member # 74251
I just finished up building a passenger drop high pinion 30 housing about a month ago and had my axle all apart, BUT I didn't take the brake brackets off.
The 7mm hex allen wrench is to bolt the caliper onto the bracket that is bolted to the knuckle.
IIRC the brake brackets that bolt to the outer knuckle, that the calipers bolt too, came from the factory with graded star shaped heads on the bolts. So its possible that they could be side specific, but I am not sure on that?
Wally
Old 05-16-2011, 07:54 PM   #6 (permalink)
sammyg's Avatar
Member # 98177
I'm betting they changed mounting in 82 when it went to wide track. Mine is the ford style caliper with a hair pin spring to hold the calipers into the brackets.
Old 05-16-2011, 08:01 PM   #7 (permalink)
Member # 74251
That would make sense. Sorry, my info wasn't much help.
Wally
Old 05-17-2011, 09:24 AM   #8 (permalink)
Member # 134251
My jeep is an 81 and there should have 1 spring clip, 1 slide clip and an oversized Allen head screw, the spring goes under the slide clip, together they slide between the caliper and the bracket, and the screw holds them in, any questions
Asking for Forgivness is easier than asking for Permission..
creer32 is offline   Reply With Quote
Old 05-17-2011, 10:48 AM   #9 (permalink)
LeadfootCJ7's Avatar
Member # 85264
Send a message via AIM to LeadfootCJ7
They did
X2
81 CJ7 258/NV4500/Dana 300 4" Skyjacker lift & 1" BL; 4.10 gears, Detroit lockers, Warn M8000
LeadfootCJ7 is offline   Reply With Quote
Old 05-19-2011, 11:47 AM   #10 (permalink)
sammyg's Avatar
Member # 98177
One big question, can you please snap a picture or 3 of the set up? I got an idea how it goes together now, but does the allen screw go on the topside of the bracket and toward the wheel? Or down and away from the wheel? Or down and toward? And do the hoses come in from the top or the bottom?
Old 05-19-2011, 11:58 AM   #11 (permalink)
Member # 134251
Give me your email and I'll get them today or tomorrow , I know the screw goes below the caliper you may have your brackets swapped
Old 05-19-2011, 12:04 PM   #12 (permalink)
sammyg's Avatar
Member # 98177
theabstract@pirate4x4.com
thanks!
Old 05-19-2011, 07:36 PM   #13 (permalink)
Member # 134251
I sent the pic let of know if you need a better pic
Old 05-19-2011, 07:59 PM   #14 (permalink)
sammyg's Avatar
Member # 98177
Perfect! Thank you! Got them straightened out and put on correctly, bled, and it works!
