Anyone know the difference between a Mean Green alternator for a 91-98 Jeep TJ 4.0 (part number 1334) and one for a 99+TJ (part number 1382). Pulley? Number of grooves? Can you make the 99+ alternator work on a 97? Thanks
The location of the AC compressor and alternator changed right around that cut off. The alternator moved up to the compressor location and the compressor moved down by the left motor mount. The only difference should be the mounting configuration.
http://www.alternatorparts.com/external-voltage-regulator-high-output-alternator-kit.html
I have 2003 Tj the ECU regulator went out a month or so ago. I found this place online I got it in the mail 2days later. It works like a champ and took 5mins to install. I also am not poping any trouble codes. I would give it a shot if anybody is having regulator issues
