I had a clunk coming from my rear suspension and found a loose bolt on the passenger side, axle end, UCA. When I went to tighten it, it broke. Then I found that the other half of the bolt was seized into the joint. When I drilled it out I didn't drill straight and drilled through the side of the pivot ball.
According to 4x4 Groupbuy, RE products won't be available til August. I desperately need a small SF joint, or actually, just the pivot ball.
Does anyone know of where I could get a pivot ball or the SF assembly? ANY help would be appreciated.
