Searched, found nothing on specifics of what I want to do.
So, since I got my Comanche, there never was an ignition key. The lock had been busted out, and all there is is a tab that I use plier to grab. Othere than that it was turning and starting just fine.
The other day I was driving around, and when I got where I was going and went to turn the truck off, I found I couldn't turn the igniton back to 'off'. It was stuck in the 'on' position. I said, ok, decided to really ream on it, still didn't budge. So my truck was stuck 'on'. I ran around like that till noon or so, and once I got my truck in the driveway, that's when I tried to stop it. Ended up yanking the distributor wire, stopping the engine.
So, no my truck is in my garage, dead until I can fix the ignition. What I want to do is catch the wires before they go up the steering column, and splice in 2 switches. One will be an 'off/run' 2 position switch, the other will be for the starter. That switch you can push up, and it returns to 'off' position when you let go, perfect for the starter.
So, the big question is, which wires do I snip and splice? I know how to do the work, just need the right wires.
Push button start, baby, oh yeah!
