First trip out in my 95 ZJ I had some tranny trouble. Tranny shifts fine but once it shifts out of first it wont go back into first whether I floor it or shift it manually into first. If I come to a complete stop is the only way it will go back to first. It will hold first fine just wont shift back down? Any suggestions? Was thinking of swapping in a aw4 but if this is a simple fix will try that first.
Could be either the throttle pressure/kickdown cable adjustment, governor pressure transducer or a valve body issue. A scan tool may be needed to check for codes and to read the pressures if adjusting the cable doesn't help.
When you hold low (Manual first) gear, does the trans allow engine braking? If so, mechanically, it's probably OK
