Allrite just got done rebuilding my motor the trans worked when i pulled it out...i drian and refill the trans fluid and installed a new filter.... was dirty but still had red color to it....got the motor and trans in my jeep and all together it drove fine up and down my driveway bout a dozen times...parked it and now it when i put into gear nothing! does matter what gear it does nada....i have no clue what happen or what could have caused this....anyone have any idea what my problem may be?!?!?!
What does the fluid look like now? I'm curious because if all you did was drop the pan then you changed out about 1/3 of the existing fluid and then replaced it with stuff that most likely wasn't compatable with it.
Regular old Dextron/Merc non synthetic is what the AW4 needs and there's no reason to be dumping anything from Lucas in there either.
