Have these which are worthless
These hinges which have a bolt hole spacing of 1 3/4 x 3 1/2 hole to hole
Bought a pair of Besttop Mirrors that were supposed to fit.
As you can see the pattern and taper is totally different. Even if I switched side to side to match up the two front holes the taper would be off. Plus the bolt spacing would still be wrong.
Besttop CR says these are late YJ/TJ and I have some bastard set up. :laughing:
Can machine up a plate (thinking Delrin) and make the Besttops work.
But I gotta believe there is a supplier that has a decent mirror that matches up to my hinge plate. Or an OEM part number. Looked at the big box stores of Jeep parts, eBay and the dealer but so far no luck.
This isn't brain surgery and should not be this hard to do. Where the hell are these things hiding ?
