Member # 130080
ax-15 vs nv4500 for 5.3 vortec
i have and ax15 but am thinking about buying a NV4500 for a 5.3 vortec i'm swaping. does anyone know how the ax15 and nv4500 compare in strength? does anyone keep there ax15 in there jeep with v8 power?
Non-Lemming
Member # 840
There is NO comparison on strength. The NV4500 is vastly stronger.
http://www.novak-adapt.com/knowledge/ax15.htm http://www.novak-adapt.com/knowledge/nv4500.htm NV4500's were put behind Cummins diesels in Dodge trucks. The AX15 would have exploded trying to handle that type of torque. Last edited by SanDiegoCJ; 06-11-2011 at 08:00 PM. |
Member # 5577
The AX-15 is a decent transmission. The NV4500 is pretty much indestructible in something as light as a SWB Jeep. Get the early Chevy version for the 6.34:1 granny low. Later versions can also be converted to the lower gear (or bought converted new). Even the later ones have a much lower first gear than the AX-15.
The bad: they expensive, heavy, and long. Not too long for a TJ/YJ though. HTH, Jake
It's all here before your eyes / Safety is a big disguise / That hides among the other lies |
#6 (permalink) | |
Member # 52989
I have another friend who had a 4.0/nv3550, but went to a NV4500 with his 5.3 TJ swap. He did it mostly because he walked into an amazing deal on the NV4500, and as mentioned, it's pretty much bulletproof in a TJ with a 5.3. -From what I can tell, they the AX15 is rated for the same torque as an NV3500 or NV3550 (300ft-lbs is the number I remember reading, but don't quote me on that). I mention this because I've got a NV3500 in my fullsize chevy with 4.8, I tow with it, I drive it hard now and then, and I've got 100k on it. Having said that, there is probably a reason it wasn't available behind the 5.3. You could get them with the old TBI 350's though. -The AX15 seems to have more aftermarket support than the 3500. For example: RSG Terminator I recall their torque rating on this modified trans being well beyond 300ft-lb (one web search said 385ft-lb) but I don't see any claims on their website now. -I also believe that with some parts swapping they can use the different 1st gears from the toyota turbo Aisin R151 (about 4.3:1) or (another toyota transmission, I forget the name) but it's somewhere around 5:1. Don't get me wrong, the NV4500 is stronger (I found claims of ~460ft-lb torque rating on the web) and has a wider gear spread. But the AX15 is smaller, lighter, cheaper, more fun to drive and with the right t-case/axle gearing I think it will do the job. It's what I would pick, but I know how I drive, I can't speak for you!
'47 Willys CJ-2A -- www.pirate4x4.com/forum/showthread.php?t=690670 Last edited by jalbrecht42; 06-12-2011 at 09:29 AM. |
Member # 156906
I can personally say that the nv4500 will hold waaay more than 460ft/lbs. I was putting over 800 through mine in my 98 dodge 2500 with a modified cummins. I've seen them hold way more than that too. They are a great trans, ill run one when I do the swap.
'56 CJ5, 5.3,T18/D20, tons, linked,42 PBR's, snowpig '07 Dodge, CCLB, 6.7, G56, deleted, towpig |
#10 (permalink) | |
Non-Lemming
Member # 840
Cali version of a 2003 RAM3500 with the Cummins. The Cummins was rated at 460 ft/lbs output. |
Member # 111955
i maybe wrong, but i don't think an automaker would put a tranny in that is only rated for 460 ft/lbs when they engine puts out that much. the tranny would not hold up to that. the ax15 is rated for 300 ft/lbs + and a 4.0 only puts out 220ish...
#12 (permalink) |
Member # 52989
Just to be clear, the point of my post wasn't that the nv4500 is only rated for 460ft-lbs (and again, I'm not even sure if that's right, that's just a number I've seen in several places on the internet). I'm not really sure how a manufacturer arrives at a torque rating for a trans, the number certainly isn't the point where the trans will break, but rather a number that allows for some amount of longevity at that level.
'47 Willys CJ-2A -- www.pirate4x4.com/forum/showthread.php?t=690670 |
#13 (permalink) |
Member # 5577
A few things:
Driveability: they don't shift quite as nice as a car transmission (ala AX-15), but they shift MUCH nicer than the older granny boxes (BW T-18, Muncie SM420/465, NP435, etc.). They are not difficult to drive on the street at all. Since it's basically a 3-speed with a granny low and an overdrive, the ratios are widely-spaced (especially on the old Chevy version) but with a big v8 and proper gearing for your tire size, you hardly notice. Regarding the reputation they have for 5th gear going out: I think this was due to a design quirk/resonance peculiar to the Cummins 6BT where it would eventually work something loose on the OD shaft. This would not be an issue in a Jeep. Price: They can be had used for under a grand. I only paid 900 for mine (early Chevy W/6.34:1 granny low), including the bellhousing. HTH, Jake
It's all here before your eyes / Safety is a big disguise / That hides among the other lies Last edited by Jakesteramalamajama; 06-13-2011 at 06:21 AM. |
#14 (permalink) | |
Non-Lemming
Member # 840
NV4500 Heavy Duty versions have an 11/4” – 10 spline input shaft and have an increased input torque rating of 460 ft-lb. http://www.mackstrans.com/NewVentureID.html |
