Rear Bumper doubling as crossmember in frame? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-29-2011, 09:32 PM   #1 (permalink)
Member # 68900
Im wondering why some people are making their rear bumper as part of their frame instead of going with a variation of stock with bolt on bumpers. Other than esthetics, I can only think of cons to this, can someone help me out with the pro's?
The biggest con I have is that if someone rear ends you your frame just got smashed on where-as on a stock jeep, the bumper will absorb some of the blow before the impact gets to the frame.
Also, now if your welded on rear bumper is wrecked you have to go cutting apart your frame to fix it, bolt on application, just turn some bolts and replace.
Anyone? Thanks...
dolanmx305 is offline   Reply With Quote Quick reply to this message
Old 06-29-2011, 10:25 PM   #2 (permalink)
Member # 110248
no bolts to break and/or stretch when you hook onto something tough. Granted I build mine to bolt on to make servicing easier down the road, But I can see where some of those bolts are pulling on a tj. On my dads cj the frame broke where it was bolted.
djljeep is offline   Reply With Quote Quick reply to this message
Old 06-30-2011, 06:17 AM   #3 (permalink)
imped4now's Avatar
Member # 124275
People who wheel enjoy the departure angle and clean looks. My bumper/recovery point is my xmember.1/4" steel welded to the rails. It's not going anywhere.
imped4now is offline   Reply With Quote Quick reply to this message
Old 06-30-2011, 07:13 AM   #4 (permalink)
rstycj's Avatar
Member # 125507
I made mine bolt on, but it doubles as a gas tank mount due to rear frame rot it had when I bought it. It will be a PITA if/when I have to remove it. Just gotta make sure the tank is empty I guess...
78 cj5 350sbc sm465
97 one ton s10 5.3/sm465/NP203/205
rstycj is offline   Reply With Quote Quick reply to this message
Old 06-30-2011, 07:20 AM   #5 (permalink)
The Devils Trailboss
UCTJ's Avatar
Member # 51571
Some people dont drive their Jeep on the street so it may not be a concern and by removing the thin crappy sheetmetal from the factory with something stronger it ties in the rear frame rails better.
2012 Dodge 3500
97 TJ 60/14 Atlas 40" Maxxis 106" WB
UCTJ is offline   Reply With Quote Quick reply to this message
Old 06-30-2011, 08:41 AM   #6 (permalink)
Member # 32145
Departure angle was the main thing I was looking for. Also, I wanted to add mounts for shackle hangers off the back of the frame for an eventual wheelbased stretch and the stock crossmember wasn't strong enough to work from.
I rarely drive mine of the street, but if I get hit hard enough to bend the new crossmember I built, I think I'd be in the same boat if I was running a bolt on bumper.
before
after
of course when I actually got around to the wheelbase stretch, plans changed a little.
bgredjeep is offline   Reply With Quote Quick reply to this message
