axle shaft question D 60 front 14b FF - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-18-2011, 11:43 AM   #1 (permalink)
370
Member # 153116
ok so my shop caught fire.. and inside the shop were all 4 axles shafts for my jeep. and also my front carrier. so heres my question. are these parts salavageable? or should i not even bother? the shafts all look just fine but what about them seeing heat? will that ruin them? where they were at theres not way they got red or anything becaue they weren't directly in the flames or anything like that. same deal with the carrier it was in a bucket under the bench. the top of the bucket melted but the carrier is inside and appears fine i know it'll need new bearings obvisouly. any insight? i should mention this is a budget build so buying brand new axles shafts and carrier is out of the question.
370 is offline   Reply With Quote
Old 07-18-2011, 02:48 PM   #2 (permalink)
In the open's Avatar
Member # 56370
Put it together and run it. start looking for spares, but i would run it. especially if it wasn't directly in the fire.
This is America, you can do whatever you want.
In the open is offline   Reply With Quote
Old 07-18-2011, 05:04 PM   #3 (permalink)
BrianDguy's Avatar
Member # 166202
x2
At the shop I work at, we harden steel at appx 1600* and temper at 580*. If they didn't get that hot, depening on the alloy, then you most likley will not have any issues.
So what your sayin' is...
BrianDguy is offline   Reply With Quote
Old 07-18-2011, 05:35 PM   #4 (permalink)
howyadoin's Avatar
Member # 84132
Free heat treating...awesome! We burned a car to the ground two years ago at SilverState and everything was junk, but I wouldn't bat an eye trying them out on a trail rig. .02
howyadoin is offline   Reply With Quote
Old 07-18-2011, 09:49 PM   #5 (permalink)
370
Member # 153116
well i guess i'll give em a shot.. and look for another good set. the 14 b FF shafts are EASY and CHEAP.. i bet my junkyard will sell them to me for $40.. it;s teh D60 front shafts that are gonna be tougher to find and probably more expensive
