Member # 144281
Capstan winches? Thinking about using one for my "retro" build
OK, so I bought that '46 cj2a I was talking about last week. Got it home and it is a real solid base for a build. Perfect frame, and decent Penn. state body. Missing the tailgate and spare tire carrier. Motor/tranny/t-case were sitting next to the thing outside and open when I went to pick up the heep, so I left them as scrap. The end goal for this jeep is to have it just for something to putz around on the trail with, no extreme stuff.
A dude comes into my shop Thursday telling me about a CJ-6 he may be getting. Says it has a strong F-head, but body has "some fiberglass" The 6 is sporting a Capstan winch which I guess is driven directly off the crank. I had a cj-6 before, it made for an awesome parts vehicle. So I may get it just because of that. Anyone have experience with capstan winches? |
Member # 7588
I always thought capstan winched were cool... I wonder if they work with the new braided winch rope?.... basically you would have unlimited rope length... except that you have to be outside the vehicle to use it
1948 Willys 1952 M37CDN Powag |
Member # 144281
How do they actuate being direct drive off the crank? A PTO would use a clutch to stop the gears, but how would an engine? Do you have to shut it off, pull the lever, start the engine?
New synthetic line should work fine |
skullfuckery
Member # 29016
i dont know how you would drive one dirrectly off the crank. you would only be able to pull left or right no forward.
since you dont know how it work and we cant see it maybe you should post some pics....
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
#6 (permalink) | |
Member # 144281
skullfuckery
Member # 29016
no clutch just a few big teeth that cob together via the handle.
Capstans
Have a capstan on my land rover. Works great. Wrap the rope around the bollard and put some tension on it and friction does the rest. Easy to use, dirt simple and allows you to use the t-case for an overdrive if you wanted. The jeep version is a little cheesier than the rover version (just like the chassis
) but you will find it surprisingly useful.
I am what I am - Popeye |
#12 (permalink) | |
Fistful of Boomstick
![]() Wrap around a few times loose, when you pull the free end friction will grab the drum and the line comes in. You keep tension andcontrol of your loose line, harder you pull the more it grabs and faster the winch pulls, less and it slips more.
Doc-14 Tactical Products: When it absolutely, positively needs to be made from random crap found in the back of my garage. You cant ban knowledge, learn to make your own guns right Here. New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight. |
