My Little MF - Page 11 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-12-2012, 10:07 PM   #251 (permalink)
Member # 146142
Just found this thread. The jeep looks awesome! Makes me want to go find a trashed mb or gpw! Are you going to have this up at pa jeeps this year?
1945 CJ2A 1.75 Superlift & 31 TSL's, 95 YJ RE 4.5 & 33's, 12 Jk Unlimited 2" & 33's J8 Build
mikeg1713 is offline   Reply With Quote
Old 02-13-2012, 05:45 AM   #252 (permalink)
Member # 80328
The jeep will be at the Jeep show for sure!
Script GPW project in progress.
b4wscrambler is online now   Reply With Quote
Old 02-13-2012, 06:36 AM   #253 (permalink)
Member # 146142
Sweet! Ive seen the scrambler there before. I had mine there last year.
I'll have my cj parked at our booth. I'll come hunt your jeep down. Maybe I'll try to follow you over the big rocks. Lol
Old 02-13-2012, 04:45 PM   #254 (permalink)
Member # 80328
I had the Scrambler there two years ago and was driving Mikes YJ around this year. I LOVE the PAJeeps Jeep Show and plan my summer around it! I have taken a 1985 CJ7, 1952 DJ3a, 1981'ish J10, 1981 CJ8, 1994 YJ and Mikes YJ. I have been to at least the last 12 Jeep shows.
Old 02-13-2012, 04:55 PM   #255 (permalink)
Member # 80328
This seems like the most expensive way I could find to plumb the filler neck.
Speedway Cap assemble
Ebay 2" aluminum 45*
Ebay 2" aluminum 90*
2' of rubber filler neck hose
6 clamps
1 3/8 barbed fitting
The 3/8 fitting is for the tank vent for filling the tank. Without this vent it takes for ever to fill the tank, silly pump will keep shutting off because of the pressure build up. The actual tank vent is on the passenger side and is not enough during fill ups.
Old 02-13-2012, 08:30 PM   #256 (permalink)
Member # 146142
I look forward to running into you and this thing! If you see me and my cj come say hi. I'll be watching you build this thing!
Old 02-14-2012, 03:44 AM   #257 (permalink)
Member # 22397
Send a message via AIM to youngblood
It looks like you could use a 90 degree barbed fitting or your vent line might collapse? Or might just be an optical illusion...
youngblood is offline   Reply With Quote
Old 02-14-2012, 07:47 PM   #258 (permalink)
Member # 80328
I was going to let it go... Thanks buddy.
Lame day working on the jeep today. I have a plan on how to mount the Radiator to the grill and trimmed up my mounts a bit. I also mounted the base plates for the C pillar.
Old 02-15-2012, 01:55 PM   #259 (permalink)
Peow130's Avatar
Member # 123919
Wanna come re-do the floor and firewall in my 3A?? Haha, jk, but it looks great man
98 Tacoma. Chick paintjob and 33's
51' CJ3A/CJV35-U SBF289, Disk swap, SOA, 3speed
Peow130 is offline   Reply With Quote
Old 02-16-2012, 01:22 PM   #260 (permalink)
Member # 5326
Originally Posted by b4wscrambler View Post
The paint is, Rustoleum 1919830 - Deep Forest Green. Basically OD Green. I try to buy a few cans a week so it is not so much of a hit when I really need a lot of it.
Thanks
I grabbed a can of the 1920830 'Army Green' a while ago and it was WAY too light, even lighter than my old Krylon paint from like 8 years ago. I'm going to try the darker 'deep forest green'.
Mieser is offline   Reply With Quote
Old 02-19-2012, 07:17 PM   #261 (permalink)
Member # 80328
Radiator mounts are done. I used short pieces of 1" square stock with 7/16 nuts welded inside, then welded the 1" square stock right to the grill.
I have about 3/8" between the fan and the bolts holding the pulley to the water pump.
I lucked out and the stock 1995 S-10 Blazer upper radiator hose fit just fine with a bit of trimming.
Old 02-20-2012, 08:52 AM   #262 (permalink)
Member # 5326
yeah, not a ton of extra room in there!
Looking good.
Do you have a shot of your clearance on the engine/firewall clearance?
Old 02-22-2012, 03:50 AM   #263 (permalink)
Member # 80328
The distributor cap is close to the cowl. I think I can get the wires on there without having to trim anything.
Old 02-22-2012, 03:58 AM   #264 (permalink)
Member # 80328
I lucked out and my spare lower radiator hose for the Scrambler was close enough to make work. It is just a simple "L" shaped lower Radiator hose.
Gates # 20957
http://www.rockauto.com/dbphp/x,cata...TES_20957.html
I had to trim it down quite a bit. I also reinstalled the stock S10 spring in the hose. Trimmed down of course.
Old 02-24-2012, 06:37 AM   #265 (permalink)
Member # 80328
Payday for the wife today meant I got to order some parts.
Power Steering cooler.
http://www.summitracing.com/parts/FLX-3812/
I needed a shifter boot but really the only reason I ordered it now is that I can not stand to pay the handling fee on just one part.
Shifter boot I went with.
http://www.summitracing.com/parts/LOK-X70-FMB/
Old 02-24-2012, 06:40 AM   #266 (permalink)
CronusTRD's Avatar
Member # 11141
Doh, I meant to tell you I'm may pull the cooler off my jeep when I install the hydro assist this weekend. PSC sent me a bigger one, but I might just use both.
Mike
RcRocs 4.3 Toyota Jeep
www.marylandcreepers.com
www.rightcoast4x4.com
CronusTRD is offline   Reply With Quote
Old 03-02-2012, 03:16 PM   #267 (permalink)
Member # 5326
How goes the project? Get stuck? Or just not enough time to take pics
Old 03-05-2012, 01:35 PM   #268 (permalink)
Member # 80328
Short on updates and motivation...
Steering cooler is in and plumbed as is the Trans cooler. Both seem to be holding fluid well. I also have the fuel lines run.
I did find out that a EDE-39106 is a very nice low pressure line (Return line) that bolts to the power steering box.
I did not buy it here. My local Napa'ish parts store had it for under $5.00.
http://www.tellico4x4.com/product_in...ducts_id/31672
For the fuel filter I went with a Wix 33300. It is a little smaller than the normal filter most people run. Perfect for tight spaces.
http://www.summitracing.com/parts/WI...n/?prefilter=1
Old 03-14-2012, 04:30 AM   #269 (permalink)
Member # 80328
Help me finish the Willy's by buying my Scrambler.
/forum/vehicles-trailers-sale/1048070-1981-jeep-scrambler-maryland.html
Old 03-14-2012, 06:22 AM   #270 (permalink)
Member # 5326
Trade you a cool flat fender for it.........its almost done I swear.
Old 03-14-2012, 06:30 AM   #271 (permalink)
superdooty's Avatar
Member # 103746
How did that lower hose work out? I have the same setup (4.3 cpi, and a Griffin with that goofy angled neck at the bottom). My hose is having to "twist" to hit the radiator, causing it to want to collapse (i have the stock s-10 hose with the spring, and a couple of aftermarket lower hoses too) .
My radiator sits closer to the engine than yours. My grill is not trimmed on the backside (CJ3b).
I'm thinking of cutting the lower neck off and angling it the other way
"...you win. I have a very limited number of facts, and you have an unlimited supply of stupid." ...Boortz
Here : /forum/jeep-willys/975300-my-junk-goldie-lox.html
There :http://vintageshasta.proboards.com/i...lay&thread=488
superdooty is offline   Reply With Quote
Old 03-14-2012, 05:53 PM   #272 (permalink)
Member # 80328
I got lucky on the lower hose. It is the one I had for a spare for the Scrambler. I trimmed it to fit and cut down the stock s-10 spring and used that to make sure that hose would not collapse.
I am pretty friendly with my local parts store so they tend to be very helpful with finding those hard to find parts. Though it sounds like you may need to cut the neck of and relocate it.
On a side note. It took 3 gallons of antifreeze to fill the little MF up. Seemed like alot to me.
Old 03-23-2012, 04:48 AM   #273 (permalink)
Member # 80328
Fuel tank holds 5 gallons at least... Fuel pump works. Tune up parts are on. Most of the under hood wiring is done. I still need to find a good spot to mount the computer. The best place is very close to where the gas pedal (that I don't have) needs to go. I will figure something out...
Old 03-23-2012, 07:20 AM   #274 (permalink)
Member # 22397
I'd guess your handy forming work only took a gallon from the capacity, and a stock zuk holds 10 gal. Glad to hear you're still tinkering with it.
Old 03-24-2012, 07:09 AM   #275 (permalink)
Heimaster80's Avatar
Member # 211407
Great build, just finished reading it from the start. I really like the floor and tunnel work, attention to detail is awesome. it's great how you have tucked everything in and made it look so clean. I KNOW it's not easy...........starting my second Willys build TODAY! Any words of advice....lol
Have any up dated pics to show of progress???
~Travis / 46' Willy CJ2A
Heimaster80 is offline   Reply With Quote
