Member # 35564
1946 crazyj2a build.
My new little project. It's a 1946 cj2a ,original drivetrain. No plans as of yet just other than gettin running decent and riding. Eventually I want to put some wagoneer axles , 5.38 gears, 35 km2's, lockers, power steering, 4.3 vortex, sm420, Dana 300 or 20. Already picked up some used corbeau ss seats.
95 jeep grand cherokee 5.2,3.5 IRO lift,km2s,(parts hauler) 1946 cj2a (new build) collecting parts Last edited by m38a1jpn; 09-08-2011 at 11:59 AM. |
Member # 35564
Picked up some pretty worn boggers . They are 31x12.50x15. Got them for 60 bucks. Needed something that would hold some air.
95 jeep grand cherokee 5.2,3.5 IRO lift,km2s,(parts hauler) 1946 cj2a (new build) collecting parts |
Member # 35564
Well after doing some looking on this board and a couple others I have this itch to go ahead and build it. Going this weekend to pickup a transmission sm420 with novak adapter to a dana 300. I scored it on craigslist for $225.00. It also comes with the bellhousing, clutch, flywheel, and starter. Also scored a front wagoneer 44 for $100.00 bucks and its got warn hubs already. I already have a rear 44. Im going to ditch the original frame and may try to make my own. Pretty pumped. It will be a long build but will be fun. Im hoping I have learned from some of my mistakes I make on my last build that I ended up parting out. Oh yeah sold the Boggers.
95 jeep grand cherokee 5.2,3.5 IRO lift,km2s,(parts hauler) 1946 cj2a (new build) collecting parts Last edited by m38a1jpn; 10-03-2011 at 07:08 PM. |
Member # 35564
Member # 5326
Make your own frame! Its SOOOOO much cheaper than buying one. I should have some prints and dwg/dxf files up soon for the one I am building. So far it fits great buy I don't know about the little stuff yet....
42 MB, 225, T18, big kid go cart with clown tires 92 Dodge W250 daily driver on 39s |
Member # 35564
Mieser, I probably will. Your build is one that has inspired me. Very nice. Your frame is sick. Defintley looking forward to prints and drawing files.
Forgot to post got finished putting lift and tires on the zj (parts hauler).
Member # 35564
Went and picked up some parts last weekend. The Dana 300 needs a rear output shaft. Other than that I think I got a great deal. The front axle is to wide. Going to sale and get a narrow track waggie 44. Definitely going to build my own frame. Here some pics. Also I have a rear offset Dana 44 axle I'm going to use.
#12 (permalink) |
Member # 5326
MMMMMmmmmm parts...
Few things I would consider. -Just build the frame for whatever spring pad width you end up with. I would say with waggy axles just building a wider frame would be MUCH easier than trying to outboard stuff. You would have to trim a few of the mounting tabs on the front fenders ( or lift them ) but overall it would make a few things much easier. You will have to outboard the body mounts a little bit, but again, not a big deal. -I would use a 5" tall section of tubing for the belly section of the frame. This will make it a little easier to get the belly smooth if you choose to go that direction. A 4" tall belly like I did on mine makes for a TIGHT area to work in. -With the centered rear output, if you raise the transmission transfer case much you are going to have to make a tunnel in the body for the rear drive shaft. Good luck with your project!
#13 (permalink) |
Member # 35564
I started tearing down the old willys last night. I didn't get very far. The stubborn and rusted 65 year old bolts didn't want to cooperate. I decided to cut the bolts but then realized I was out of cutting wheels. I did get the front and the wiring ( what was left anyway) either cut or taken off . I called and got pricing for tubing for the new frame. Here are some pics.
#14 (permalink) |
Member # 35564
Got the body off the original frame and all I can say is I don't know what I got myself into. Haha. It's gonna be fun.
#16 (permalink) |
Member # 127313
very nice, can't wait to see your fab work.
Nobama, I don't mind working for my money, you shouldn't either. Willys Build http://pirate4x4.com/forum/showthread.php?t=824952 “If you don't have time to do it right, when will you have time to do it over?” - John Wooden RIP "Let every man have a pistol, instead of one man have a tank." |
#17 (permalink) |
skullfuckery
Member # 29016
do you still need an output shaft?
$51 shipped.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
#18 (permalink) |
Member # 35564
Yes I do need rear output shaft for Dana 300. I will pm u.
#19 (permalink) |
Member # 5326
Looks like another cool flat fender project!
Any thoughts on the frame? I can get you some prints, but to be honest my frame is kinda specialized a bit with the side plates, wheel base shifting, and rear springs up front. If you tell me what your thinking for a final frame I might be able to help you out a bit more. All in all the 2x4 box frame is pretty easy to build, you just need a few key points and can go from there. Heck, I think building my frame was one of the easier things I did once I got into things like the rear wheel tub modifications!
#20 (permalink) |
Member # 35564
Mieser I really like your frame. What will your final wheelbase be. I will hopefully pick up my tubing within the next couple of weeks. It will be 2x4 tubing.
#21 (permalink) |
Member # 35564
Well I sold the chassis. Time to get some 2x4 tubing. Also got a rear Dana 44 out of rodeo/ passport. Got it from a buddy. Ready to start building the frame.
#25 (permalink) |
Member # 35564
Thanks Mieser. I pmed savaras about the the exact dimensions of his frame. I think the wheelbase I'm looking for is 89-90 inches. I hope to get that or around that.
