Dana 25 broken axle - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-04-2011, 09:21 AM   #1 (permalink)
Member # 108128
Dana 25 broken axle
I broke the passenger side axle in my dana 25. I have a dana 27 out of a 65 scout. Will these axles interchange?
kirbybuilt is offline   Reply With Quote
Old 10-05-2011, 09:36 PM   #2 (permalink)
Member # 108128
Ttt.
Old 10-05-2011, 09:42 PM   #3 (permalink)
sammyg's Avatar
Member # 98177
Should be 10 spline inner/outer on the CJ... Pull the scout one out and look. I think a 65 is wider track. I'd compare them side by side.
I don't always show my signature. But when I do, it's in this area.
sammyg is offline   Reply With Quote
Old 10-06-2011, 05:19 AM   #4 (permalink)
wilez5150's Avatar
Member # 86194
different wms
USN 2x Viet Nam Vet.
member Victor Valley 4 Wheelers hammer road crew
42willys 109" rock dog with some stuff
51 willys 106" with some fast stuff
retired wheeler
wilez5150 is offline   Reply With Quote
Old 10-06-2011, 08:23 AM   #5 (permalink)
Member # 108128
thanks for the input. If anyone in the Fresno/Oakhurst area has a short side axle or the whole assembly pm and we will see if we can make a deal.
Old 10-06-2011, 08:24 AM   #6 (permalink)
Member # 5326
What style shaft? Is it the u-joint version?
Mieser is offline   Reply With Quote
Old 10-06-2011, 07:10 PM   #7 (permalink)
Member # 108128
No it is the closed nuckle style and uses big ball bearings(not sure what the correct term is for this style).
Old 10-06-2011, 08:06 PM   #8 (permalink)
Member # 169497
dana 25
I have a dana 27 that will work in San Luis Obispo, ca. I liked the ujoint 27 axles much better than the berfields that were in the 25. I have a ton of other parts too.
slo02dodge is offline   Reply With Quote
Old 10-06-2011, 09:04 PM   #9 (permalink)
Member # 108128
How much are you looking to get for your 27? Will my 5.38 work in a 27?
Old 10-06-2011, 09:22 PM   #10 (permalink)
Member # 169497
The axle shafts will fit but the gears will not. That might be the gears that it has because it came out of a cj 5 but I would have to check. 80 dollars and you can have it
Old 10-07-2011, 03:38 PM   #11 (permalink)
Member # 108128
The price is right on, but I'm not heading that way until the spring. If I can't find anything closer then I will concider making the trip. Thanks.
Old 10-08-2011, 08:25 PM   #12 (permalink)
Member # 111535
Not sure what your Dana is in but I have a complete Dana 25 minus hubs out of a Wagon. PM me if that will work for you.
Come on we need our own Willys section.
Thanks I have a religion.
Clipity is offline   Reply With Quote
Old 10-08-2011, 08:38 PM   #13 (permalink)
sammyg's Avatar
Member # 98177
All dana 25's were closed knuckle, it doesn't matter if you use bendix, rzeppa, or spicer style joints. Sounds like you had a bendix axle shaft
I ran a 27 in mine, but went back to a 25 when I blew up the 5.38's (Impossible to find for a Dana 27, well, not impossible, but pricey... I have a set of 5.38's in the garage for a 27) The 25 has a bigger ring gear than a 27. All parts were interchangeable except the R&P....
If you have a CJ, now's a good time though to find a narrow track Dana 30 from a pre 82 CJ... Only 2 inches wider than a Dana 25, most come with discs and 5.38's can be had for them. You'll have to space the rear axle though. YMMV.
Old 10-10-2011, 09:06 PM   #14 (permalink)
Member # 108128
My long term plan is ro put waggy 44's under the jeep. I have the rear axle bit saving up for the front. Dont want to put too much into an axle im going to get replace soon.
