Swing/Hanging Pedals - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-16-2011, 06:32 AM   #1 (permalink)
Member # 154165
What pedals have you guys used for swing pedals in your jeeps. The last ones I put in my 2A were from a mid 90's mustang but I was hoping from something a little easier and stronger. Any suggestions of what worked well?
lawsonj5 is offline   Reply With Quote Quick reply to this message
Old 11-16-2011, 06:48 AM   #2 (permalink)
Member # 41645
I read somewhere(cant remember where) that cherokee pedel sets are a perfect match for the 2a
MACHINIST is offline   Reply With Quote Quick reply to this message
Old 11-16-2011, 07:02 AM   #3 (permalink)
Member # 5326
An XJ pedal pack seems to be about the perfect fit for a flat fender. I have a link or two in my Rango buildup. You can still get them surplus for like $40 new.
You can do just the auto version with a brake pedal only....or you can do the manual version with hydraulic clutch.
I am in the process of trying to make a nice template for the conversion as part of my build.
Old 11-16-2011, 07:51 AM   #4 (permalink)
CRO
Member # 7588
I used CJ7 pedals cut down because I still run a mechanical clutch linkage (bellcrank).
I also have pushed the drivers side footwell out to get more room for swing
1948 Willys
1952 M37CDN Powag
CRO is offline   Reply With Quote Quick reply to this message
Old 11-16-2011, 08:14 AM   #5 (permalink)
fcfred's Avatar
Member # 3263
advance adapters has a kit, but it uses a funky master cylinder. i'm sure a willwood or such could be adapted.
http://www.advanceadapters.com/produ...ing-pedal-kit/
Team Tank
old junk, new junk, unfinished junk
Live Large-RIP Jason Payne
fcfred is offline   Reply With Quote Quick reply to this message
Old 11-16-2011, 08:47 AM   #6 (permalink)
Brian1's Avatar
Member # 2205
Cut down YJ pedals with a wilwood hydro clutch
Brian
NMOffroad.com
Brian1 is offline   Reply With Quote Quick reply to this message
Old 11-16-2011, 09:27 AM   #7 (permalink)
Member # 141981
Send a message via ICQ to 46WILYZ
http://www.pirate4x4.com/forum/showt...ighlight=pedal
KK6MWD "46WILYZ previously known as 1946cj2"
pirate4x4.com/forum/showthread.php?t=968398
46WILYZ is offline   Reply With Quote Quick reply to this message
Old 11-16-2011, 09:35 AM   #8 (permalink)
Member # 141981
Here's a picture at the bottom of my wilwood master cylinder. I can get a picture of the pedals later, but for now this is all I have.
Originally Posted by 1946CJ2 View Post
I got some work done yesterday. To start with My flywheel and clutch kit. Everything fit and bolted up great, between the sm420 and the chevy 4.3. The kit was for a 92 chevy pickup.
The adapter ring was from novak to mate the sm420 with the sm465 bellhousing.
The bellhousing I used was from a 65 chevy pickup with a factory clutch slave. However, I can not use the stock exhaust manifold no, because it dumps out into the slave.
I got my firewall all welded up.
And I mounted my wilwood clutch and brake master / pedals. Wilwood rep, said it should work with no problem, will see. If not I do have a hydroboost set up, but I did not want to run it if I do not have to. I did leave enough room to mount the hydroboost in the same location as the brake mastercylinder, without moving the clutch master.
Old 11-16-2011, 10:47 AM   #9 (permalink)
Member # 154165
I'de like to stick with off the shelf parts as opposed to wildwood or similar. I think the XJ pedals sound like a good option. Do you have to cut anything off the main frame or do they stuff up under the dash pretty nice?
Old 11-16-2011, 10:57 AM   #10 (permalink)
Member # 5326
You have to trim a bit off the top of the frame it looks like. I will have all the details in my build thread when I get that far. No trimming the pedals though, and you can run the booster directly inline ( if you can fit the booster ). I will be making a manual brake master cylinder adapter for mine.
Old 11-16-2011, 06:36 PM   #11 (permalink)
Member # 80328
This is the one I picked up for my junk. 90's XJ with a Automatic.
Script GPW project in progress.
b4wscrambler is offline   Reply With Quote Quick reply to this message
Old 11-18-2011, 06:34 PM   #12 (permalink)
Member # 26465
I used XJ Pedals in mine.
46 CJ2A, 5.0, C4, D300
MDDimmick is offline   Reply With Quote Quick reply to this message
Old 11-19-2011, 06:53 PM   #13 (permalink)
Member # 5326
Anyone have access to a manual trans XJ that can measure the mounting location for the clutch master cylinder.
I reverse engineered the location, but I would like to see how close I got....or at least know I am in the ballpark....
Old 11-19-2011, 07:51 PM   #14 (permalink)
Member # 80328
I had a friend measure his and all he could tell me is that they are 8" apart center of cap to center of cap.
