Biggest tires with 80" wheelbase? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-13-2012, 11:03 AM   #1 (permalink)
Member # 213940
What's the biggest tire size people are running with an 80" wheelbase Willys or CJ5 rockcrawler (or similar rig)? I'm on 35's with D44 front and rear on XJ springs- thinking about 37's, just curious what others were running on non-stretched jeeps that still flexed well?
Yeager1 is offline   Reply With Quote
Old 05-13-2012, 08:56 PM   #2 (permalink)
Member # 211856
Depends on how much trimming you do I guess. I ran 37s Boggers but they are more like 34s on my flattie with a 80" wheelbase. I now run 38.5 Boggers on a 87" leaf spring stretch but there're like a 36".
52flattie is offline   Reply With Quote
Old 05-13-2012, 09:09 PM   #3 (permalink)
6,000lb diesel ZJ
Black sheep fabworx's Avatar
Member # 215954
Cool
The biggest Iv ever run on a CJ is a 35 with out stretching it out. They were in the fenders all the time, with about 5" lift.
Don't let my new join date/post count fool you, Iv been a member for10 years!
Those who say it can not be done should not interrupt me when Im doing it!
Black sheep fabworx is offline   Reply With Quote
Old 05-14-2012, 11:51 AM   #4 (permalink)
Moderator
geberhard's Avatar
Member # 5861
Moving to Willys forum.
geberhard is offline   Reply With Quote
Old 05-14-2012, 01:05 PM   #5 (permalink)
Tinkerer
oldtimingman's Avatar
Member # 75774
35's are biggest I've ever run.
oldtimingman is offline   Reply With Quote
Old 05-14-2012, 01:11 PM   #6 (permalink)
Member # 171057
i have mine stretched to 84" without modifying the body at all, and though i've swapped in yj springs i don't think it is lifted above stock much if any. currently i am on 32" MTR's and considering going to 33's, though i have to say, the other day i parked next to a jeep sporting a brand new set of 35" MTR's and i don't see much of a reason why those wouldn't be awesome on a rig of my size. might require a touch of rear fender trimming.
I think beyond a 35" tire, a more serious stretch would be in order, but i think a mild stretch and a low suspension would work great up to that point.
1950 CJ3A Wilma FJ60 axle build in progress
1999 Ford F350 PSD Betty tow pig/adventurmobile
euroford is offline   Reply With Quote
Old 05-14-2012, 01:34 PM   #7 (permalink)
Captain who knows
Rooney77's Avatar
Member # 82435
I have 2.5" bds yj springs on a stock wb cj5 running 33" tsls. I've got metal cloak all the way around so 35s would be possible. Given the wb, I wouldn't go over 35 without stretching.
My diesel flatfender build:
http://www.pirate4x4.com/forum/jeep-...eys-build.html
Originally Posted by ironpig70 View Post
Fawk some people are idots.
Rooney77 is offline   Reply With Quote
Old 05-14-2012, 04:28 PM   #8 (permalink)
Peow130's Avatar
Member # 123919
80 inch tires before the tires rub eachother
98 Tacoma. Chick paintjob and 33's
51' CJ3A/CJV35-U SBF289, Disk swap, SOA, 3speed
Peow130 is offline   Reply With Quote
Old 05-14-2012, 07:56 PM   #9 (permalink)
Member # 817
38.5 X 11:00 Boggers, rear fenders trimed. Q buckshots (34"ish) when it was stock with some rubbing.
53' willys cj3b. 44's front and rear,t-98,300 c.i. ford six 38" boggers winter, 35" BFG's summer.
CJ3BWILLYS is offline   Reply With Quote
Old 05-15-2012, 09:49 PM   #10 (permalink)
Member # 67890
Hey Roseburg, Ore. nice looking 3B.
GreenJeep55 is offline   Reply With Quote
Old 05-16-2012, 06:56 AM   #11 (permalink)
Willys LS
SVARAS's Avatar
Member # 9310
Couple of bad ass Jeeps
Wagoneer 6.0L / RAM 2500 Cummins 5.9
4WOR 2012 Ultimate Adventure Invited Reader
Willys LSX in Progress
SVARAS is offline   Reply With Quote
Old 05-16-2012, 07:15 AM   #12 (permalink)
Member # 5326
As long as you keep the chassis/body nice and low I don't really think there is much of a limit on tire size vs wheelbase. However, in order to do that you need to move the axles around a little bit to get the tires to clear somewhat fixed points in the chassis.
I kept mine REALLY low with 35" tires, basically only 1" of lift over stock. To do this I raised the front fenders up 2.75" and the rear tubs basically the same amount (and enlarged the rear wheel openings ). The rear axle pretty much HAD to go back 2" to get the front of the rear tire to clear the step on the tub. I moved the front axle forward about 3" but could have probably gotten by with 1-2" if you wanted to avoid all the changes you could.
I wouldn't have any problem going out to 40" tires with enough small modifications to keep the height WAY down.
Mieser is offline   Reply With Quote
Old 05-16-2012, 09:34 AM   #13 (permalink)
jeepcj's Avatar
Member # 20502
I have had 38" Swamper on my 59 cj5 with a spring over
jeepcj is offline   Reply With Quote
