Axle upgrade - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-17-2012, 09:38 PM   #1 (permalink)
Member # 226324
Axle upgrade
I came across a rear 9 inch 62" wms-wms and a hp 44 front 63" wms-wms. I am currently almost complete with a dauntless swap in my 59' cj with stock running gear. I just want to get it back on the trail!! I don’t plan on swapping axles until I break the stockies. So I have time to collect other parts. I need a 4spd and driver drop transfer that is compact. Everything is over 28" long. Any suggestions?
59 cj5,oddfire,saginaw power steering,sprung over,5:38 stock44-25,time bomb
willie1eye is offline   Reply With Quote
Old 08-17-2012, 09:43 PM   #2 (permalink)
Member # 5326
Just about any granny 4 speed with a flipped Dana 300 behind it should be plenty short enough. Dana 300's run fine flipped as long as you do a little work on the shift rail shafts.....
Mieser is offline   Reply With Quote
Old 08-18-2012, 07:26 AM   #3 (permalink)
wilez5150's Avatar
Member # 86194
/\ what he said or maybe a turbo 350/300 if your lazy like me
USN 2x Viet Nam Vet.
member Victor Valley 4 Wheelers hammer road crew
42willys 109" rock dog with some stuff
51 willys 106" with some fast stuff
retired wheeler
wilez5150 is online now   Reply With Quote
Old 08-18-2012, 08:48 PM   #4 (permalink)
Member # 226324
That sounds like a good option. What about a ford dana 20 ( bronco) adapted to a t18?
Old 08-18-2012, 09:41 PM   #5 (permalink)
Member # 5326
The ford adapters ( to ford transfer cases from basically early bronco applications ) are generally longer than D300, D18/d20 stuff.
Don't be afraid to flip a D300. Its VERY easy to roll over to the other side. You don't really need anything fancy. You can make a set of cable shifters or a set of lever shifters fairly easy. You don't need to buy any of these super expensive 'flip-kits' that are on the market in my opinion.
