Willys Tow Rig - Page 11 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-08-2017, 07:34 AM   #251 (permalink)
Member # 104219
I would vote using the copper only since it can handle higher temperatures (500F vs 400F). I've not had any experience though using it in a head sealing application. What can it hurt?
Alex
57 CJ5 - Under Construction
Que_Honda! is offline   Reply With Quote Quick reply to this message
Old 02-08-2017, 09:37 AM   #252 (permalink)
49willys_mogon's Avatar
Member # 78325
Permatex: against
This might be better option.
HYLOMAR AEROSOL ADHESIVE :: Adhesives & Sealants :: Scheid Diesel
49willys_mogon is offline   Reply With Quote Quick reply to this message
Old 02-11-2017, 02:34 PM   #253 (permalink)
Newbie
Member # 731657
WOW Very Nice!
Eat Dirt 65 is offline   Reply With Quote Quick reply to this message
Old 02-19-2017, 07:12 PM   #254 (permalink)
Member # 101740
Amazing Build!!
Love the concept.
TJS 4x4 is offline   Reply With Quote Quick reply to this message
Old 03-07-2017, 09:09 PM   #255 (permalink)
FST
Member # 226569
Thanks for the compliments guys.
Not a whole lot of excitement going on as of late. Gearing up to media blast her with some crushed glass, do some body work, and finally do the paint. Anyone willing to drive to Yakima to help out with some body work? Lol
On another note. I want to be able to haul my dirtbike in the bed. Any Ideas for tie down points?...
FST is offline   Reply With Quote Quick reply to this message
Old 03-12-2017, 07:55 AM   #256 (permalink)
FST
Member # 226569
So for now I just hooked the straps through the ends of the tubes.
Bikes fit perfect.
Old 03-16-2017, 07:13 AM   #257 (permalink)
Member # 152618
Nice build.
Build a tiedown strip alonge the front edge on the bed at the floor or bolt some d-rings to the bed with backing plates, rivets would ad an old feel look/touch, plys gives you tie down points around the bed.
MKR5150 is online now   Reply With Quote Quick reply to this message
Old 05-18-2017, 06:25 PM   #258 (permalink)
FST
Member # 226569
So I haven't gotten a whole lot done with the Willys lately. I've been wanting to work on the fuel delivery system for a while now. Because of how shallow and wide my tank is, I have a huge problem sucking air whenever I get down to 1/2 a tank. So to help remedy the issue I made this bolt in sump out of stainless that also has a simple baffle network, better than nothing anyways... I also ran 1/2" ID Line from the tank to the modified mechanical lift pump running the comp cams upgraded spring.
When you have access to a laser and part of your building is rented out to a tire store, you can easily make your own gaskets....
Of course the tank is upside-down in this picture.
It's not the prettiest but overall I am pretty impressed with it. I have a little less than 1/4 tank right now and on the drive home I was really hard on it: quick braking, WOT pulls, drifting around corners... I removed the wood out of my bed and ran a clear return line so I could watch for bubbles. I only got aeration one time when I came around a left corner, oversteered, and then jerked back. I feel like I gained some mid/high range power too. I think the 1/2" line is helping to keep the fuel pressure around 55psi (where I have my Watts valve set on the return line). I didn't have my gauge hooked up but before when it was sucking out of a straw, I could get that gauge down to 12psi on a WOT pull.
Old 05-18-2017, 06:41 PM   #259 (permalink)
Marion Cobretti
72blazer's Avatar
Member # 40131
No videos of the debauchery?!?!
Motorsport Syndicate:::Edinburg TX
Bitches today are too fucking uptight.
72blazer is offline   Reply With Quote Quick reply to this message
Old 05-18-2017, 06:48 PM   #260 (permalink)
FST
Member # 226569
Lol. Need to get a GoPro. There will be video of me running at the track tomorrow. They have "Diesel Days" drags every may.
Old 05-20-2017, 10:04 AM   #261 (permalink)
FST
Member # 226569
Some videos from the Diesel drags last night.
http://youtu.be/9-3WnCjluso
http://youtu.be/RsSehpFaNuU
Old 05-21-2017, 09:15 PM   #262 (permalink)
csutton7's Avatar
Member # 4962
I didn't see what size o-ring you went with and if you o-ringed just the block or also the head. I originally used .040 wire on my head and it blew after a while and then I o-ringed the block with .050(if my memory serves me correctly), yea both were oringed. Then I used a copper head gasket and coated it with yamabond 6b(5b didn't hold up on one of my tries), but the 6b and copper head gasket was still holding when I sold it. Hopefully yours stays together now, but what I did worked for years. I'm sure they've got it figured out real good now, but this was back in the day when twins and NOS were somewhat new in the diesel world.
chris
--my '48 build:
csutton7 is offline   Reply With Quote Quick reply to this message
Old 05-22-2017, 10:25 AM   #263 (permalink)
FST
Member # 226569
.040 stainless wire with .010 protrusion. Stock cummins gasket with arp 425 head studs. The second time I blew it was just because of a lack of retorques; VERY IMPORTANT. I have them torqued down to 135ft/lb and it has been holding great.
Old 05-22-2017, 10:31 AM   #264 (permalink)
FST
Member # 226569
I was really surprised to be hearing the tires screeching off the line with an 18psi boosted launch... I think they didn't really prep the track much because it was just diesel night. I'll tell you what, the sump and 1/2" line definitely made a difference; while my transmission is still shifting too late and it starts defueling (if I don't let of the pedal to get it to shift) It is for sure pulling harder in the 3600 to 4000 rpm range where before it would fall off REAL quick.
I did blow out at least 1 or 2 exhaust manifold gaskets on my last race running down a duramax with a 4 second head start. lol
Old 05-22-2017, 11:16 AM   #265 (permalink)
fredycruger's Avatar
Member # 225557
WOW
fredycruger is offline   Reply With Quote Quick reply to this message
Old 05-22-2017, 09:13 PM   #266 (permalink)
FST
Member # 226569
Oh. I forgot to mention how I almost didn't make it to the Diesel Drags the other night... on the way home from work to pick up the wife and head out I pulled a grade at WOT and 85psi for a few seconds and all of a sudden I heard a shotgun go off from under the hood!
Old 05-23-2017, 05:44 AM   #267 (permalink)
GTOffroader's Avatar
Member # 34347
That's not how it's supposed to look.
1958 Willys CJ-3B "Pile'o'parts"
GTOffroader is offline   Reply With Quote Quick reply to this message
Old 05-24-2017, 11:27 AM   #268 (permalink)
FST
Member # 226569
I'm new to the whole Instagram thing but we are starting up a page for people to follow progress of the #WillysTowRig Please feel free to follow and share.
https://www.instagram.com/willystowrig/
Old 05-24-2017, 05:16 PM   #269 (permalink)
FST
Member # 226569
I pulled the cab to get the exhaust manifold off today and replace the gaskets that blew out.
And I noticed that the WH1C just must have been pushed too hard. Cracks all the way around the exhaust housing.
Old 06-03-2017, 07:10 AM   #270 (permalink)
FST
Member # 226569
12.16! New best, and there's still more there.. I let off completely at 1000 foot attempting to not "break out". Still broke out. I vice gripped the TV cable before this run to try to get it to shift closer to where I want, still not perfect but definitely an improvement. I can feel my single disc converter starting to slip though.
Sorry that the video is dark and a little blurry.
http://youtu.be/pRp5Wg2d558
Old 06-19-2017, 11:30 AM   #271 (permalink)
FST
Member # 226569
After wanting a GoPro for quite a while, I finally got one.
https://instagram.com/p/BVh3iHNjxCf/
Old 06-19-2017, 04:15 PM   #272 (permalink)
Member # 682169
This is what I like about this forum. Even though I don't drag race anything I've got I really enjoy reading your thread and keeping up with your progress. The truck is definitely badass, can't wait to see some vids. And good luck at the races!
WILLYN is offline   Reply With Quote Quick reply to this message
Old 06-20-2017, 05:26 AM   #273 (permalink)
Member # 34347
Likewise, everything I own is slow but I do enjoy seeing a truck haul ass especially if it's a diesel.
Old 06-20-2017, 05:26 AM   #274 (permalink)
Member # 34347
Also, the seeing the fab work gets the idea wheels turning.
Old 06-20-2017, 10:33 AM   #275 (permalink)
FST
Member # 226569
Thanks for following guys!
I come from an off-road background and even have 1 or 2 cherokee build threads on here. So naturally when it came time to build the tow rig, I wanted to post a build thread on here as well.
Thinkin of using this belt to hold the Jerry can.
